A custom clutch line?
I would like to create a custom clutch line from the master to slave but not sure how to go about doing it.
Has anyone done this before or have any ideas how to?
It's been done a bunch of times. I did mine with a 7 feet of 3AN SS line and appropriate adapter fittings to attach the line to the slave and master.
You can buy the parts yourself or have a shop make a line for you. Looking back I would have just gone to a hydraulic shop, because they can just crimp the ends on and you don't have to worry about doing all the fittings yourself. I had a shop do a custom line for my Chevy/RX7 and it was only $45
Also, just run a straight line master-slave. You don't need all the union/damper bullshit that's on there from the factory.
You can definitely write-ups on this site, if you need them..
Right.. I should've clarified. I meant places like summit/jegs sell the AN hoses.. but after fittings you'd probably be in the hole the same amount as having one custom made, which is why I agreed with ya.
One helpful thing to add... I did it a while ago, but I'm almost positive our master is 12x1 and the slave was 10x1.
