91 crx not starting
Intermitent problem, sometimes it starts sometimes it doesn't.
checked spark and am getting plenty of it. distributor ok. feeling it has somthing to do with fuel pump but as its intermittent it can't be gone can it? what should i do??? could it be a sensor or relay etc?
anyone had same-ish problem
got the circlip done the other day cost 4 quid for the clip and 50 quid to put it on, crazy yea!!
thanks everyone for your replies, highly appreciated
it could be your main relay that makes fuel pump ect kick on by your ignition switch, you say quid so im assuming your somewhere around europe, idk how much it would be over there but in the us its like 50 bucks, you should also test the fuel pump and look for any loose or broken wires. hope this helps.
Hy,
Go to this website ... It's your Main Relay I've got the same sympthom of my Civic i16S, it's the same Motor. http://techauto.tripod.com/
Good Luck!
Good Luck!
I've been thinking its my main relay for a while because unsurprisingly to most die hard crx lovers the car starts when its cold or coolish outside but if its warm or warm in the car it will give me trouble. I started it at midnight last night and it started straight away but was giving me problems all day yesterday. That relay really needs re-soldering.
Thanks everyone for your replies
Took a crack at the relay today at work
None of the solder points on the PCB looked dry at all but still touched them all up and now I'm puzzeled as to how I know if it works or not lol
Thanks everyone for all the advice
egthomas
17
May 20, 2009 02:21 PM
