timing belt part questions
Hey guys, I'm buying parts for a timing belt change, and I have the following..
water pump - 19200-P72-013
timing belt - 14400-P72-014
tensioner - 14510-P30-003
tensioner spring - 14516-PR4-A00
valve cover gasket set - 12030-P73-000
ac belt - 38920-P73-003
ps belt - 56992-P72-004
alt belt - 31110-P73-A01
the water pump, tensioner, and tensioner spring all cross reference Honda part numbers from my local Honda dealer's website. They have the same part number, so I'm assuming its the same part.
But when I read this post, https://honda-tech.com/forums/acura-integra-type-r-8/quick-question-itr-timing-belt-water-pump-they-same-civic-si-model-1126924/ , someone mentioned that the b16 water pump is different. But the part number on Delray Acura and my local Honda dealer are the same for that pump. Is the info in the thread true, that the pump for the Si and ITR are different?
Thanks
Thanks
no they are the same. i ordered my water pump, tensioner/spring for my itr though the honda dealer. you could even order the valve cover gasket set though honda just use the 99-00 si part number. pretty much its the same thing
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
mattsnooz
Apr 9, 2007 03:57 AM
reno96teg
Apr 25, 2006 05:06 AM
98LS4dr
Feb 1, 2005 11:36 AM
boostincoupe
Sep 5, 2003 06:36 AM
