How to remove carpet?
Is there any video or tips on how to remove the carpet.
The previous owner of my car was a pig and the carpet is really dirty. I want to remove it so I can pressure wash it.
I know the seats need to be removed. I have removed the fronts already which is no problem. I need to know how to get the side door sils (sp?) off and how to remove the rear seat. Also does the center consule need to be removed?
Hi,
What type of car do you own again?
Carpets are easy jobs to do.
The side sills honestly just pull right off just be decisive with the movement so there's no damage to the plastic itself. A quick and clean pull and the clips will pop out.
I got the carpet out the side pieces just snap in place.
There is a spot near the ebrake and shifter where the carpet goes under those and I just cut the carpet. I wasn't going to remove the ebrake and shifter just to get the carpet out.
The rear seat you have tp reach your hand under the front on both sides. There is a little plastic tab that pulls out and releases the seat. The is also a bolt in the rear of the seat on the passenger side.
I pressure washed the carpet and let it dry over night. It looks 100 times better now.
