What grit sandpaper for sand 97 ej6 coupe..painting car
Old Jun 10, 2011 | 01:22 PM
MatakiRotorD16's Avatar
Default What grit sandpaper for sand 97 ej6 coupe..painting car
Not trynna sand down to metal, just get down to the primer, then primer and paint
Also, how many cans, ive got 8 primer and 8 color currently
Old Jun 11, 2011 | 07:55 PM
(. )( .)'s Avatar
Default Re: What grit sandpaper for sand 97 ej6 coupe..painting car
Youre spray bombing your car? Youll need about 30 cans. Youll need a good clear coat also and wet sand he orange peel after.
You dont have to sand to bare metal unless youre going to use filler. If youre going to repaint, just scuff up the surface and shoot your base than clear. Prep the surface very good before anything
Old Jun 13, 2011 | 06:34 PM
prelude1897's Avatar
If you're just wanting to sand the clear coat on the car, I suggest using 800 grit, then rattle can the hell out of it afterwards. It's going to look good for a week or so, then turn to ****, but it's your car and you can do what you want. Most people here would suggest using real car paint
Old Jun 14, 2011 | 11:14 PM
ninjaturtleEG's Avatar
Unless the current paint is cracking and peeling then you dont have to sand it down to primer. You just need to scuff up the paint with 600-800 grit.
UnoPuntoCinco
Paint and Body
May 26, 2007 04:00 PM
cilvia
Nov 11, 2006 11:34 AM
4ghatch
Jun 27, 2005 08:55 PM
Full Race A6
May 30, 2004 09:53 PM
cracker099
Nov 30, 2002 11:14 PM
