PA:FS/FT D,B,F,H Parts,OEM&Speed Parts
Whats up guys ive got alot of Honda+Acura Parts i need to Sell to pay some Bills...I can also Trade...Phone Number 724-984-6442 Location Smithfield,PA,15478 10 Mins from Uniontown
NOTE I Do Not Have Paypal ATM...I accept Post Office Money Order or Western Union...I have alot of Vouchers to say im legit
Things ill take for trades
1.TIAL 38MM External Wastegate
2.B18A/B ARP Head Studs
3.Stage 3 or Better ACT/oR OTHER Clutch Disc B-series Hydro...2500 Miles or Newer
4.No name 30x10x2 Front Mount
5.T3 Turbo/5 Bolt Flange....Garrett...Precision...TurboNetics Mayb others
Ive also got alot more stuff i just dont remember all Im reasonable But sometimes are Firm
Ill try to put AfterMarket Parts first
1.Brand New OEM Replace Stage 1 Pressure Plate...For 94-01 B-series Hydro Trannys....Its from advance bought in Clutch kit OEM was like $158.00 i bought stage one for $240.00 I had aftermarket Pl8&flywheel already so asking $50.00 Firm
2.XTD Stage 3 Pressure Plate ....For 94-01 B-Series Hydro Trannys....4500 Miles on it...Great Shape...$35.00 OBO
3.NOS Blue Bottle/With Bottle Brackets...It Says Cylinder Weight 8lb 3 oz &Cylinder&Gas Weight 13lb 8oz So i was thinking its a 8lb Bottle..Its a Really Nice Bottle...Has HIFLO Nozzle...Goes for $159.99 & Brackets $49.99 (Note Did Not Include Price for HIFLO Nozzle)These Price's on EBAY Which is Cheapest Prices...Im Asking $140.00 Firm
4.AIRTEX 190 Lph High Flow Fuel Pump....88-91 Civics....Still in Box..Bought it thinkin would mayb work in my EG &Didnt Only took out to mount....Paid$159.99 on Ebay 2 years ago....Asking$65.00
5.HF Sohc Exhaust Manifold....Used on SOHC for turbo Set up...Mint Painted high heat black....$45.00 Obo
6.Brand New In Box Nippon STD 81mm B18A/B Pistons&Coated...Bought From EBAY As Turbo Pistons I guess there Not Cast Aluminum Like OEM...So they dont Crack a ring Lands...Does Not Include Rings...Paid $179.99 On Ebay
Asking $125.00 Shipped(Note These Have Wrist Pin Oil Squirters)
7.92-95 Civic Ex Auto Gauge Cluster...128,xxx Miles...Has Tach..Mint...$40.00 Obo
8.D16Y7 OBD2A Auto ECU...$35.00 OBO
9.D15Y5 SOHC VTEC-E 5 SPEED ECU OBD1...$45.00 OBO / Also have a New 5 Wire Oxygen Sensor for this y5..Motor Blew up 300 Miles After Spendin $169.99 Asking $50.00 OBO
10.92-95 Civic HatchBack...FULL Driver Side Quater Panal...It goes from Door Jam...Under rear window...half up rear piller..Around taillight...alll the way around wheel down to skirt....Has a Rust hole in quater But its so easy to fix off car...this is perfect for someone has caved in corner...its nice....they sell these for $225 new....ill ask $80.00 its full rear back of car
11.OBX Stainless Steel T3/38mm B-Series Turbo Manifold...Only Used for 2 Dyno Runs&2 Street Pulls..Then my tuner sold me a Drag Log Mani...$60.00 Shipped
12.88-91 PGMFI OBD0 Intake Manifold D16A6...Complete..Also Includes 4 Red injector Clips/w Pigtails...(PERFECT For Muti Port swAPERS...$42.50 OBO
13.92-95 Civic CX Black Dash..Super Mint....Doesnt have botto, piece where ashtry and cig lighter is&No cluster..Hard to find With no Passenger Air Bag..Im sure dash harness is there....Asking $80.00 FIRM Or for $110.00 I can Include Auto EX Cluster/w Tach
14.92-95 Civic Full Fuel Pump Set up...Pump has under 50k Miles...Replaced wit walboro...Its full Cap/Mount/Pump...U just drop and plug it in...$45.00 OBO
15.D15B7 obd1 Distributor...Has 80k Miles..But new cap/Ignitger &Coil etc replaced 20k miles ago...$50.00 obo
16.88 CRX SI 3pc Tail Lights..Fresh....All 3 Pieces....$75.00 fIRM
17.B18A1 Valve Pan Cover...Sand Blasted to Bare Aluminum...Cut for Cam Gears...$30.00 OBO
18.96 Civic 4 Door...Trunk Lid..Flat Black..But Mint...$40.00 Local Pick Up only (Also Have Mint 4 Door taillights for $40.00 obo OR TRUNK&LIGHTS FOR $70.00
19.92-95 Civic Coupe EX Only ...Burnt Orange Painted....Includes Inner Lights...No holes for wing...Mint...$50.00 Pick Up Only
20.97 Civic Coupe Tail Lights OEM.....Really Fresh....Are not 00 SI....$45.00 FIRM
21.195/70/14" Tires Good shape 65% THREAD....im asking $35.00 For both
22.94 Integra Power Steering Rack&Pinion....Works Perfect...$60.00 obo
23. 95 Civic EX Power Steering Rack&Pinion...Perfect....$60.00 Obo
24.94 Integra LS Steering Colum&Has Ignition/w.....No steering wheel...$75.00
25.94 Integra Black Passenger Power Door Panal...Has Cloth On the accent...$20.00 Obo
26. 94 Integra LS Black Coupe Rear Back Plastics...$40.00 Obo both
27.95 Civic CX Black Rear Plastics...Does not have panals for speakers...Great shape...$40.00 OBO
28. 38mm External Wastegate/w 6.7 Psi Spring...$45.00 Shipped
29.92-95 Civic EX Passenger Door...No Panal...Power door....It has shavd molding...Its burnt Orange...Couple dings....$45.00 Obo Pick Up only
30. B16A OBD0 JDM Set up....All Has Been Disassembled But I will list what is Missing
-B16A JDM/Block...Crank is Mint(Does not need Turned....Rod are Perfect...Has Oil Pump/Water Pump/Oil Pan/Baffle...Sleeves are Nice....Things this block Needs are Pistons/Rings/Bearings(DISASSEMBLED)
-B16A JDM HEAD..Exhaust side Ported...JDM Cams/Cam Caps/Lmas/8 Duel Valve Springs/8 Singles/Retainers/All Valves But 5 that are bent....Head did drop a valve &chambers arnt pretty but local machine shop pressure tested/cleaned/resurfaced...Everything is in plastic bags....Head Needs ,Valve Cover,Vtec solenoid,Dizzy,5 valves
-B16A OBD0 Intake Manifold...Includes Fuel Rail/Line/Injectors/Throttle Body..Sensors
-ZDYNE B16A OBD0 5 Speed Aftermarket Ecu
-Also Have Both Axles...Can be used as Cores or can replace Boots..
-Also have B16A OEM Flywheel&can Include XTD Stage 3 Pressure Plate.
EVERTHING Listed Above ill take $400.00 Obo Willing to take some Trades
31.D15B2 OEM Replacement Pressure plate...New Just has been setting for 2 years....Never ran....$35.00 Obo
32.92-99 Civic Mint A/C Compresser....Came off 95 Ex wit 75k Miles....$45.00 Obo
33 92-95 Civic Full P/S Set up....Lines From Rack...Lines From Pump...Pump..Bracket...Belt...Bracket.Front Cooler..$65.00 Obo or Can Include P/S Rack for $55.00 Extra
34.92-95 Civic AEM Blue Cold Air Intake..Has Brackets so u can bolt it....Its mint..Has Aem Stick on &Perfect& Has C.A.R.B Sticker on it to....These go for $240.99 On Ebay its a awesome Intake...Im asking $120.00 Obo Willing to work in trade also with something
35.B18A1 Block...Mint...Crank Is perfect...Pistons&rods are perfect...i would put bearingss& rings in it...asking$120.00 OBO
36.92-99 Civic Front OEM Struts ,Springs,Top hats.....Car had 71k Miles....$50.00 For Both OEM Complete Strut&Springs
37.JDM Motors KNOCK SENSOR...Its got like 3,500 Miles...Orderd from Japan for 149.99....Asking $65.00 Firm
38..Lots of Intake Manifolds...All Listed Here is BARE But can Make Complete for right price....JDM B16A OBD0 Intake Manifold $30.00 OBO.....D15B7 OBD1 Intake Manifold $20.00 OBO....B18A1 OBD0&OBD1 Intake Manifold(I have Both) $25.00 Each
39. Fuel Pumps OEM 95 Civic EX OEM Fuel Rail Replaced 20k Miles Ago $50.00(Includes Full Screen/Mount Bracket/Fuel Tank Cap//94 Integra GSR Oem Fuel Pump&Screen 81k Miles..Might have been replaced Not sure...$35.00 OBO
40..JDM B16A OEM Intake Tube/w OEM Filter(Not Box Just filter)Tube is Like TYPE-R Replica....$45.00 /94 Integra GSR OEM Intake Tube/w Air Box...$32.00/95 Civic EX OEM Intake Tube/wAir Box $20.00 OBO
41.97 Civic Grey Front Seats...Good Shape Mayb Minor Tear...Needs Rails...Super Lite....$50.00 Obo (Selling for Buddy
42.92-95 Civic Coupe/Hatch Stock Size Cat Back Exhaust/No Cat its a Flex Pipe Replaced/&OEM Resinator was Removed &Put Purple APEX-I On it...Dont have Axle Back But can make one...$50.00 Obo
43.95 Integra LS Power Steering Rack....Great Shape...May Need 1 Outer Tie Rod thats It....$50.00 Obo
44.94 Integra GSR Oem Sunroof/w Grey Slider...I think i even got switch...$70.00 Obo
45.92-95 Civic EX Coupe Trunk Lid/w Inner taillights Included...Trunk is Mint(No Spoiler or Holes...Is painted Burnt Orange Like the 350z or SRT4 Color $50.00 Obo
46.92-95 Civic EX OEM 14" Hub Caps...Painted Black..Can repaint Silver no bigg deal...Great Shape...$35.00 All 4 OBO
47. 94 Integra GSR Passenger Side..Black/Grey Door Panal...Good Shape Mayb 1 Flaw....$20.00 Obo
48.94 Integra GSR BLACK Rear Plastics..Fair Shape $35.00 For both Sides/ Also have 92-95 Civic Hatch CX Black Rear Plastics $45.00 for both sides OBO
49.WISECO B-Series 81mm 8:8 Turbo Pistons...3 Pistons Have 2,000 Miles on them i melted 1...But i Ordered a New one Its Brand new..Also Orderd 4 BNIB Wiseco Race Rings&Wiseco Heavy Duty Wrist Pins....These Are Perfect No big deal that 3 Pistons got 2k Miles&1 is New....These go for $545.00 Shipped New...Asking $400.00 Pretty Firm(Willing to trade for Good T3 Turbo Name Brand or B series Top mount mani
50.92-95 Civic CX Fron Spindles...Both have Good Wheel Bearings.....I can include Rotors that i Replaced 1500 Miles Before Tooken Off....$50.00 Each Side
55. EG,EK 92-99 Civics&94-01 Integras...Cruise Control Units...I have like 6 or 7....Asking $25.00 Each Obo
BUMPO IF VIEWED
BUMPO IF VIEWED
tooslohatch
Jun 22, 2015 04:45 AM
Boosted_01 R
Transmission & Drivetrain
Oct 30, 2009 10:49 AM
