92 del sol ls swap
Old Jun 9, 2011 | 07:03 PM
keeblerelf09's Avatar
Default 92 del sol ls swap
going to look at a 1992 full ls swap. has ls tranny and ecu. are there anything that i should look for raise an eyebrow at or anything. anything helps here. also he said battery is dead and he said this cause the fuel pump to work off and on. i have a friend who has a fuel pump anyway to make sure its just the fuel pump and not anything more serious?
Old Jun 10, 2011 | 08:17 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 92 del sol ls swap
So....the motor is still in the car but it's not running, correct? A dead battery either works or it doesn't....
Old Jun 10, 2011 | 08:24 AM
JDM-sol 89's Avatar
Just a reminder that you will also need to find del sol VTEC shift linkage or chop out like 3" from your original shift linkage for the swap the work properly.
As far as the fuel pump goes, I would just bring a battery with when you go pick it up/ look at it because, the majority of the time its either a bad fuel pump or bad main relay; usually not a bad battery.
Old Jun 10, 2011 | 07:04 PM
hondatuner34602's Avatar
i wouldnt waste my time on a ls swap u will better off u get a bseries engine that is vtec u will be satisfied if u did unless u planning do a ls turbo which is nice cuz the compression ratio is bout perfect for a turbo build
Old Jun 10, 2011 | 08:02 PM
thanks for the responses i went and saw it complete pos rust everywhere -__-
sbpphoenix
Jul 7, 2008 04:50 PM
civic2liters
Jun 1, 2008 08:11 PM
nafreak
Aug 10, 2006 05:17 PM
soopafly828
Feb 17, 2003 12:38 AM
