Very Sporradic Power Outage
Old Jun 9, 2011 | 04:57 PM
Akodo's Avatar
Default Very Sporradic Power Outage
Hi Guys,
A rare problem has just happened again to me today and I am at a loss of what it could be.
The first and 3rd times its happened (in a 6 month span), when attempting to start my car, it suddenly lost all power (Including clock and head unit memory), the power outage continued for about 30 seconds which then everything returns to normal. I did not touch or do anything when the power returned.
The 2nd time it happened the car was off and locked, and I had noticed it had lost power when I was unable to unlock using my fob. Once again, after a period of time power returned and other than a clock reset and what not all was normal.
Anyone have any ideas for me to try? Thanks!
-Nigel
Old Jun 9, 2011 | 05:09 PM
fcm's Avatar
fcm
Old Fart
Default Re: Very Sporradic Power Outage
Check your batt. to chassis and chassis to engine grounds, do not just eyeball them, remove them clean both contact surfaces and reconnect.
If that does not solve the problem, do the same with the main power connections, batt. to engine bay fuse box and the main fuse, again remove clean and reconnect.
If that does not solve the problem, swap out the batt. although very uncommon connections of the posts to the plates inside the batt. can "break" and the symptoms are the same, intermittent loss of power when starting car, will work again after a bit, will get progressively worse untill anytime you crank engine you lose power. 94
Old Dec 27, 2015 | 12:18 PM
Gpg's Avatar
Gpg
I am having similar problem with my 2010 honda odyssey. Were you able to find the solution?
Old Dec 28, 2015 | 05:15 AM
MotoCARR's Avatar
Have you checked for corrosion on the battery terminals?
Old Jan 12, 2016 | 10:08 AM
revsdr's Avatar
Loose ground?
Realdon65
Honda CR-V & Element
Sep 4, 2021 12:15 PM
hondaown247
Honda Civic (2006 - 2015)
May 7, 2015 01:53 PM
authentic plusONErandy
Aug 14, 2007 04:45 PM
Heat Rave R
Jun 4, 2002 09:53 AM
