??? 89 CRX TRAILING ARM BUSHINGS ???
Old Jun 9, 2011 | 02:48 PM
M-FISK34's Avatar
Icon2 ??? 89 CRX TRAILING ARM BUSHINGS ???
I JUST GOT A REAR DISC SET UP. I GOT THE BUSHINGS OUT, AND NOW I CANT FIND THE REPLACEMENT BUSHINGS. THE ONES FOR 90-93 INTEGRA 94-01 INTEGRA AND 88-91 CRX ARE ALL SMALLER THEN WHAT CAME OUT. CAN ANYONE HELP ME OUT????????
Old Jun 9, 2011 | 03:01 PM
MarkOlson's Avatar
OG Hot Rodder
Default Re: ??? 89 CRX TRAILING ARM BUSHINGS ???
The 90-93 Integra bushings are bigger than the ones for the CRX/Civic. It sounds like that is what you need:
http://www.energysuspensionparts.com...prod=16%2E7107
Old Jun 9, 2011 | 03:09 PM
M-FISK34's Avatar
I'VE GOTTEN THE OEM REPLACEMENTS AND FOUND THEY WHERE STILL A HAIR SMALLER THEN WHAT CAME OUT.
Old Nov 15, 2011 | 11:03 PM
M-FISK34's Avatar
OK. STARTING THIS OVER. I FOUND THE CORRECT BUSHINGS. I STARTING LOOKING AT THE TRAILING ARMS. NOTICED THEY LOOK THE SAME AS THE ONES THAT ARE ON THE CAR NOW. IT LOOKS LIKE I CAN JUST SWAP HUBS. ALL THE HOLES LOOK LIKE THEY MATCH. I WANTED TO KNOW IF ANYONE HAD ANY IDEA IF THE HUBS WILL FIT. I CANT SEE ANY DIFFERENCE.
Old Nov 15, 2011 | 11:11 PM
Bently_Coop's Avatar
Steve at Heart
Why do you type with CAPS lock on?
Why don't you just bang out 1 pair of bushings and put it in the trailing arms with disc brakes? It would save alot of headache as transfering the hub can be a real pain with the torks bolts on back.
Old Nov 16, 2011 | 07:04 AM
M-FISK34's Avatar
sorry, the caps lock is on for work.
Im trying to save a little $. The bushings that match the trailing arms I have are cheaper. If I do that I can take the other bushings back.
Old Nov 16, 2011 | 07:26 AM
Deetz's Avatar
Crazy Honda Guy
http://www.nolathane.com.au/bulletins/Update%200402.pdf
Old Nov 17, 2011 | 11:36 AM
Tyson's Avatar
The 90-93 integra bushings are NOT the same as later integra and civics. They are larger. But you can grind out the rubber from the old ones and press the new smaller bushings in the older casing.
What are you talking about hubs for? Hubs are what the wheel bolts to.
Old Feb 14, 2012 | 06:29 AM
dano670's Avatar
Just read this post. All of the local parts stores direct you to Moog K80668 or Dorman 905-750.
I just searched rock auto and it directed me to 905-751 with a 3.3" diameter. I may have solved my problem. Thanks for this.
Old Feb 14, 2012 | 09:28 AM
Steve at Heart
The OP asked if it is possible to remove the hub and spindle from one arm and place on the other. It is possible and may require some heat to remoe the torks head bolts on back. All of the 88-91 civic trailing arms are the same. Not sure if the 90-93 integra spindles are the same though or compatible?
marcsed6
11
Dec 27, 2009 07:02 PM
98integralsB18
Oct 21, 2008 12:31 PM
crxnatic
11
Sep 3, 2008 04:29 PM
type Gendy
32
Jul 23, 2004 01:31 AM
sleeperCRX
Sep 25, 2001 07:35 AM
