RPM gauge stopped working
Old Jun 9, 2011 | 02:32 PM
mibayaua's Avatar
Default RPM gauge stopped working
I have a 1988 DX hatchback, with a D16Z6 swap, I was going to work started the car and noticed that the needle stayed on zero and not moving at all, it stopped working, that's the first issue, the second one is, after driving for a few miles and I turn the ignition key off, and try to start the car again, it will start but immediately shuts down, I have to wait a minute or two, start it again with a little tap on the gas pedal and it will stay on idle, I changed the distributor, and the engine still does the same, then I turned it on and off a few more times and somehow it stays on idle, I was guessing that I might have to allow some more time for the engine to run. Any help would be much appreciated, thanx.
-Mike
Old Jun 9, 2011 | 04:42 PM
mibayaua's Avatar
Default Re: RPM gauge stopped working
anyone experienced at least the RPM gauge not working at all?
Old Jun 9, 2011 | 04:56 PM
fcm's Avatar
fcm
Old Fart
What is the D16Z6 out of? 94
Old Jun 10, 2011 | 12:28 AM
mibayaua's Avatar
Yes, it came from a '94, any suggestions?
Old Jun 10, 2011 | 05:49 AM
fcm's Avatar
fcm
Old Fart
LOL, nevermind.
If the engine bay harness is also from a 94 Civic then there is a 2 pin connector with one blue lead in it, "TACH TEST CONNECTOR" on pass. side of where batt. is on a 94 Civic, use a DVM set to A/C volts and test the voltage at the connector as you rev. the engine. 94
Old Jun 10, 2011 | 10:37 AM
mibayaua's Avatar
LOL, nevermind.
My harness was made by RYWIRE
Old Jun 10, 2011 | 10:44 AM
Former User's Avatar
Did you install an OEM or aftermarket distributor? The latter is a common source of Civic problems. For the tach problem, use a multimeter to test for continuity on the blue wire between the igniter unit and the cluster connector.
Old Jun 13, 2011 | 12:54 PM
mibayaua's Avatar
It's a distributor I got from Autozone, I have not use a multimeter, so how exactly is the process to do that?
Old Jun 16, 2011 | 11:58 AM
mibayaua's Avatar
Actually, RPM gauge issue is still there, but the stalling went away, still not sure what's causing the RPM gauge to act up, any more suggestions how to fix the issue? The motor idles normal and runs normal
Old Jun 19, 2011 | 11:21 AM
mibayaua's Avatar
Somehow, the RPM gauge issue went away, after a few days when I replaced the distributor cap and rotor, distributor is also a remanufactured
TooCheapToGetANewCar
Oct 18, 2007 04:08 PM
jdmstreethatch
Oct 25, 2006 01:26 PM
philkehn
Aug 25, 2006 10:10 AM
eg92b16a2
Nov 29, 2004 09:50 AM
