dont understand this setup i bought
Old Jun 9, 2011 | 01:25 PM
salyboy25's Avatar
Default dont understand this setup i bought
Okay so i dropped a valve and plan on getting this motor back on the road.... I was told it is a b20vtec... but i pulled the piston and its on a p72 rod and is a p3f piston... can anyone tell if it is possible to have this in a b20 or is it a b18 block... Also what pistons should i get to raise my compression
Old Jun 9, 2011 | 01:41 PM
salyboy25's Avatar
Default Re: dont understand this setup i bought
buuummmmp plz someone help me understand this
Old Jun 9, 2011 | 02:03 PM
94eg!'s Avatar
#1 Super Guy
Loved
P3F piston is a CRV part. That means you've got the larger B20 sized bore on your cylinders. If the block has the 1-piece siamese cylinder liner, it's def a B20 block. They probably droped in a GSR crank and rods which reduces your stroke slightly but gives a slight higher/better r/s ratio for high rpm running.
Old Jun 9, 2011 | 03:30 PM
UncleD's Avatar
Huh??
Old Jun 9, 2011 | 06:27 PM
salyboy25's Avatar
yeah its the one piece.... i was told to do this nearly impposiible....should i just keep those p3f pistons
Old Jun 9, 2011 | 06:36 PM
salyboy25's Avatar
buuummmpp... ne1 got any suggestions on pistons??
Old Jun 10, 2011 | 12:15 PM
salyboy25's Avatar
No help on the pistons...its a b20block p3f pistons with a gsr crank and p72 rods and a b16 head.. thkin p30s but idk if itll work with those rods....
Old Jun 10, 2011 | 08:24 PM
UncleD's Avatar
If you had a 87 crank with stock pistons, your compression is gonna be retarded low. Who the F did you buy this motor from??? I'd take this piece of **** and throw it through there living room window....what kinda clowns are "building" motors these days?
Old Jun 10, 2011 | 08:40 PM
SL0WEGG's Avatar
They won't fit the bore. You need 84mm pistons.
like low 9:1 if that lol
PinoyShadow
28
Oct 11, 2011 10:11 PM
freakin
May 1, 2006 02:38 PM
Mentat Ghola
10
Apr 16, 2004 06:07 AM
Red99CivicSi
18
Oct 15, 2003 11:39 PM
275Performance
Oct 24, 2002 04:28 PM
