what do i need to install a/c in my 90 std hatch
My car clearly didn't come with a/c. So I'm not sure what I'm going Toners to swap it into my car. I'm sure the electrical is there but non of the lines or anything are. If anyone has any insight into this please help me
Got any worthy junkyards in your area? I miss being around Salem/Portland Oregon. They had some excellent junkyards out there. Orlando FL is not the same. Sucks here for junkyard finds.
Anyways, look around in junkyards for the dash parts like the climate control and wiring harness. As you tear into a junkyard car you'll learn where stuff goes. Makes it easier to work on your own car. It's how I learned lots of stuff about cars.
Get a new a/c compressor and condenser, not used stuff. A used evaporator would be ok, just flush it out with a/c system cleaner.
If your around the Los Angeles area i have the engine bay components you need. Sorry but i am only doing local delivery or pick up.
OK I'm putting this in and cannot figure out where all ofnya/c harness plugs go. There is a 2 prong that connects to the box that distributes my a/c. Following that there is a plug with a delete on it. The n a 6 prong plug with 4 wires on it. 3 on top, and one right below in the middle. Then a single wire white plug that I have no idea where it goes. Then a big white plug that goes into a sensor on the a/c line, then a big green plug for the fan. Oh and the small red wire plug that goes to the compressor. Anyone have any idea where that single white wire plug goes?
Already have that plug. There is that one. Its on the fire wall. And the one I couldn't find is under the hood on the fuse box. Thanks though
this post https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/c-work-my-new-89-crx-2959640/
Has the wiring diagram.
looks like the white wire goes to the condenser fan relay.
spurek
75
Sep 15, 2021 02:36 PM
metalslug
28
Jul 17, 2011 03:24 PM
E36 Guy
Jun 24, 2005 12:04 PM
The AntiRice
Jan 16, 2005 09:25 PM
