DPFI TPS, what do you do?
Omni doesn't seem to make them anymore.
No one else does.
Junkyards? Sure, if you have all day to go looking.
Multi-Point conversion? On a daily driver?
Engine Swap? Is your wallet that deep?
Tell me what your solution was.
No one else does.
Please do NOT use the TPS off the multiport. They turn in opposite directions. No wire switching will make it work because where they mount onto the throttle body, it is only allowed to turn in one direction. The MPFI TPS is designed to turn in the other direction than the DPFI TPS. I'll post a picture soon of the two, but basically they are mirror images of each other. I spoke with someone at omni, and he hasn't seen anybody make one compatible with the DPFI. The only options I know of, after researching this for the past 2 weeks are junkyard TPS or switching to MPFI. I chose the junkyard TPS.
Chris Dodd
Sep 10, 2013 12:28 PM
mattie_96
18
Nov 7, 2005 11:19 PM
tangledwebster
Oct 8, 2002 09:35 PM
