Classic Hondas All Pre-1988 Hondas.
Thermo Vacuum Valve?
Old Jun 8, 2011 | 05:31 PM
1988HADX's Avatar
Default Thermo Vacuum Valve?
Where can I get this from? I got my new Thermostat housing case today...and tried to unscrew the old valve...and ended up breaking a vacuum fitting. Found one that appears to be like mine, but it has 3 hose connections not 2.
If anyone has one, Ill buy it...prefer used...cant afford $50.
Pics Below
Old Jun 8, 2011 | 05:54 PM
realred96's Avatar
Default Re: Thermo Vacuum Valve?
Be sure you get the right one. They work at different temperatures. You should be able to snag one of those out of any junkyard btw.
Old Jun 8, 2011 | 11:16 PM
1988HADX's Avatar
I will check that...id have to ride a bicycle about 3 miles to get to a junkyard...ack...then again, i gotta do what i gotta do...might need to try pulling the fan temp switch too...i think mine is junk as the cooling fans never shut off.
Old Jun 9, 2011 | 08:06 AM
1988HADX's Avatar
17355-PH2-013 THERMOVALVE, CARBURETOR
Old Jun 9, 2011 | 06:41 PM
realred96's Avatar
That fits any accord from 87-89. Good luck, riding a bike is good for you. I ride 150 + miles a week.
Old Jun 9, 2011 | 10:36 PM
1988HADX's Avatar
In the confort of a car or bike?
Problem is...my car is Canadian...or is that not a problem? This valve is the only thing stopping me from putting motor completely back together....
......but amazingly......i put my distributor back on...pumped the gas...and it started right up......so I must be doing something right....for once.
Old Jun 10, 2011 | 08:58 AM
realred96's Avatar
I guess I should have specified...I ride ON the bike.
I am also struggling with those thermo valves on my 83 Civic. I am not sure how necessary one or both them are in the 100 degree temperatures here in Houston.
I may not even hook them back up, unless I get drivability issues.
Old Jun 10, 2011 | 09:05 AM
1988HADX's Avatar
anyone needing info...I searched for hours lastnight not finding anything...then woke up...and BOOM....found what I was looking for.
For my 1988 Honda Accord...my OEM part number for the sensor pictured above is...OEM # 17355-PH2-013
If you try interchanging this number....pvs36....youll come up with Part Number: CRB 229088 which is the same as my OEM number. Napa has them...but not spending $75.
Old Jun 10, 2011 | 09:06 AM
1988HADX's Avatar
Product Line: Echlin Fuel System
Attributes:
# Ported Vacuum Switch Hose Connectors : 2
Ported Vacuum Switch Color Code : Black
Ported Vacuum Switch Hose Size : 3/16"
Ported Vacuum Switch Temp Rating : 160 Deg
Ported Vacuum Switch Thread Size : 3/8" x 19 BSPT
Features and Benefits:
NAPA Echlin Products Meet Or Exceed Original Equipment Specifications. All Products Are Top-Of-The-Line Quality, & 100% Tested & Inspected In An Environment That Is IS09000 Compliant.
Warranty:
Limited 12 Months
Warranty PDF
Important Information:
Color Code: Black & 2 Ports
155-165 Degrees
w/ OEM # 17355-PH2-013
Old Jun 10, 2011 | 03:59 PM
poorman212's Avatar
If you can't hunt the local bone yards...Humm, the 87 is about to go to the bone yard.......my son stopped, too bad the girl behind him was on her cell...a** end has had it....PM me if you can't find one.
Back in the day, the parts catalogs-the paper ones, had all kinds of spec's so I would find the right spec's for a customer and get them taken care of...might not be the right color but as long as the open/close, temps, ports (size and number), threads were right...call it a day.
...if it is really bad I've seen "redneck" (and I'm one) fixes...super glue's, ect...can get you by.....or loop the lines for time period, when cold the car my run like XXXX, but you have about 4 months before it gets real cold in IA.
Old Jun 10, 2011 | 04:45 PM
1988HADX's Avatar
i called the salvage yard here..all he has is a 93 accord. What you want for yours?
Old Jun 14, 2011 | 05:50 AM
88LXi68's Avatar
try www.car-part.com
They won't have that part listed, but it would let you see who in the area may have an 86-89 accord in their yard.
Old Jun 14, 2011 | 09:00 AM
1988HADX's Avatar
eh Im not worried about it anymore...im letting it goto the junkyard...tired of buying stuff for it...bought the dang thing for $600...and it needs more then that put in just to get it road ready. Most of the bolts are rusted so its making it too hard for me to work on it, because I have to buy power tools...and other tools...I think I will stay away from older hondas.
Jasper_db1
Honda Motorcycles
Aug 12, 2009 08:23 PM
02BlackDC5
Honda Motorcycles
Jul 31, 2007 08:10 PM
mrdiao
Honda Motorcycles
12
Jul 11, 2007 12:42 PM
JSTOCK
Honda Motorcycles
13
Dec 21, 2005 12:51 PM
Dee
Honda Motorcycles
11
Apr 29, 2004 03:36 PM
