Cluster swap, a light doesn't seem to be working.
Old Jun 7, 2011 | 06:56 PM
Kevins89notch's Avatar
Default Cluster swap, a light doesn't seem to be working.
99 DX
I got a cluster from a manual trans car via ebay. I swapped the speedo over, and installed it. Half the tach isn't lit up. I've tried swapped bulbs from the factory cluster to the new one, but can't seem to figure this out.
Old Jun 7, 2011 | 07:15 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Cluster swap, a light doesn't seem to be working.
Do you have a multimeter?
Old Jun 7, 2011 | 07:17 PM
No.
Old Jun 7, 2011 | 07:23 PM
Former User's Avatar
Either a gauge light bulb is burned out or a receptacle is bad. First identify which gauge light bulb is not lighting up:
Old Jun 7, 2011 | 08:02 PM
Well, I got it working. The gauge light with the two black wires that run up to the other small light...I somehow think it wasn't properly set or something. It's not working, as is every other bulb, I got it bolted it, took it for a test drive, and everything works as it should. Awesome upgrade for $70.
Zhu962
Nov 18, 2008 07:23 PM
CTR_B
Mar 20, 2008 09:47 AM
Hellarogue
Nov 18, 2005 02:34 PM
CL1accord
Jun 24, 2005 09:59 AM
RTW DC2R
May 23, 2004 06:20 PM
