Turbonetics Complete Turbo kit GSR VTEC 94-98 $1800 from pan to top
Old Jun 7, 2011 | 06:52 PM
low13da9's Avatar
Default Turbonetics Complete Turbo kit GSR VTEC 94-98 $1800 from pan to top
contact :pm me
Price:$1200 4K ON KIT...FULL KIT
Trades:high comp.b20vtec longblock w/tuned ecu obd1
b18c5 longblock w/ecu obd1
i have a complete used gsr turbonetics turbo kit for sale
comes with,tapped oil pan,cast manifold for a.c and p.s,return line an oil pressure sensor w/adapter for return line,all vac.lines,3 bar map sensor,t3/t4 turbo,msd boost retard and adjuster,,2 injector with its injector adjuster box for tuning,wastegate,intercooler
Turbonetics Complete Turbo System Acura Integra GSR VTEC 94-98
$3,479.99
Turbonetics Turbo Systems are for you, whether you have a four cylinder sport compact or a V-8 muscle car, Turbonetics Turbo Systems include everything you need from fuel and ignition to piping and fittings for complete bolt-on turbo performance.
Pieces mount to existing factory positions and maintain all optional equipment including air conditioning. With these kits you no longer have to worry about 4 - 6 weeks of downtime to get a kit fabricated because our kits can be installed within 8 - 12 hours.
In addition, you don't have to worry about inexperienced tuners experimenting with your car, because our fuel and ignition management systems come pre-programmed to maintain a consistent air/fuel ratio and timing control under all conditions. Unlike others, we can back this up with the MoTeC or Horiba real-time five gas air/fuel meter and in-house dyno testing.
Kit Includes*
•Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E)
•Spearco Intercooler System
•Powder-Coated Intercooler Piping
•Silicone Hose / T-Bolt Clamps
•Exhaust Manifold - high carbon cast-steel with ceramic coating
•Fuel / Timing Controller (electronic fuel / timing management system)
•Fuel Injectors
•"Evolution" Wastegate Assembly
•"Raptor" By Pass / Blow Off Valve Assembly
•Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge
•Intake System with Air Filter
•All necessary Hardware, Hoses, and Fittings
Old Jun 8, 2011 | 06:02 AM
Thrule01's Avatar
Default Re: Turbonetics Complete Turbo kit GSR VTEC 94-98 $1800 from pan to top
miles on setup? any shaft play? comes with any ecu/engine management? what kind of power were you making?
Old Jun 8, 2011 | 12:41 PM
low13da9's Avatar
4K EVERYTHING IS ON THREAD
Old Jun 8, 2011 | 09:36 PM
low13da9's Avatar
1200 new price
Old Jun 9, 2011 | 10:05 AM
low13da9's Avatar
new price
low13da9
Mid-Atlantic (Sales)
Jun 12, 2011 10:14 PM
ItzTw
May 22, 2003 04:37 PM
