I am hating cars more and more... ***gigantic pics inside***
Old Sep 30, 2002 | 09:23 PM
Jeff 360's Avatar
Default I am hating cars more and more... ***gigantic pics inside***
Sorry about the size of the pics but I dunno how to use my new photo hosting thing...
So during this time without my car I figured I would borrow my boys car while he's away to cali...so far I've had to rewire the driver side lighting system, replace a transmission, a speedometer cable, an axle that was bent...an axle that I just destroyed (today), and paint the door and bumper all in all I dunno if I'ma ever get my swap done [frown]
The CRX
The Tranny Top
The Tranny Bottom
Oh yeah and two views of todays adventures with the 2 day old axle
Old Sep 30, 2002 | 09:37 PM
MrTodd's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (Jeff 360)
Heh, that sucks big time! How did you screw up that newer axle??? And what happened to that tranny?
Give us some info on your swap, I'm interested.
Old Sep 30, 2002 | 09:54 PM
shortyz's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (MrTodd)
o my.
Old Oct 1, 2002 | 12:40 AM
xtrafastcivic's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (shortyz)
did you know you have a hole in your tranny....
Old Oct 1, 2002 | 02:11 AM
Home Skillet's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (XtraFastCRX)
JB Weld
Old Oct 1, 2002 | 04:14 AM
keithv's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (Home Skillet)
i had my tranny case break in the exact same spot. i think we cross threaded the mount bolts with stressed the case and caused it to break...
looks like you have been having some tough luck.
Old Oct 1, 2002 | 04:15 AM
EP3_05's Avatar
That looks my old S1 transmission.......
Old Oct 1, 2002 | 08:41 AM
kranked91dx's Avatar
JB Weld
yep, or tuck tape at least
Old Oct 1, 2002 | 09:36 AM
E-AT_me's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (kranked91dx)
dude, that's friggin awesome!!!
Old Oct 1, 2002 | 11:41 AM
JohnysZC's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (Rexman)
that sucks man.
break out the red shop rags and start wipping
Old Oct 1, 2002 | 04:57 PM
Jeff 360's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (JohnysZC)
It's a B16A1 swap, I still dunno why the tranny did that, I broke the axle by havin' the wheel turned hard to the left and when I pushed on the gas apparently pushed to hard cause as soon as I did the car made a horrible ;sdliufeoija; noise and that was that. Anyways, I'm pickin' up a new axle today so we'll see what happens.
Old Oct 1, 2002 | 05:12 PM
ijjz's Avatar
Wow, that sucks. Look at it this way, at least the car has not blown up!
Old Oct 1, 2002 | 05:18 PM
.nate's Avatar
Default Re: I am hating cars more and more... ***gigantic pics inside*** (ijjz)
Lesee I spun not 1 but two rod bearings (seperate motor builds) in the same day, locked up oil pump, broke a axle and threw it thru the oil pan. Crank is fucked now... youre not so bad off
Old Oct 1, 2002 | 06:34 PM
charjacq's Avatar
New User
Hey man, civics are not tough enough for off roading! Stick to paved roads!
Old Oct 1, 2002 | 06:38 PM
Loco Honkey's Avatar
Do an autopsy on that tranny to see *why* it failed so it can be prevented. From the looks of it, the pinion shaft wore down, and when you stomped on the gas, it blew, shattering the differential, and busting the case.
Old Oct 1, 2002 | 07:54 PM
Qfactor's Avatar
something similar happened to a friend of mine, he used to downshift alot say from fourth to second fifth to second, etc. people just learn the hard way in some cases. btw I've got an S1 transmission casing if you need it.
B18C5-EH2
Jan 20, 2010 05:23 AM
k3nnex
Feb 13, 2008 03:17 PM
a1320addict
Mar 10, 2006 09:53 PM
RTW DC2R
Feb 9, 2004 06:01 PM
drjondurst
55
Feb 13, 2003 09:38 AM
