Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Best procedure to check fuel pressure?
Old Jun 7, 2011 | 06:10 AM
j.bro's Avatar
Default Best procedure to check fuel pressure?
Whats the best way to check fuel pressure on D17's?
Specifically, should I create some sort of adapter to hook up using male & female ends of the quick release (is this possible?) or do i have to add a t-joint to the fuel line and then repair using a straight section.
Old Jun 7, 2011 | 11:56 PM
It Wasn't Me's Avatar
Default Re: Best procedure to check fuel pressure?
Buy one: http://www.helminc.com/helm/product2...C01&itemtype=N
First you're going to need to relieve the fuel pressure before you disconnect the fuel line.
1. Remove the main fuel relay. Behind the glove box, there are two relays next to each other. Remove the one on the left.
2. Start the engine and let it idle until it stalls.
3. Turn the ignition off.
4. Remove the gas cap to relieve tank pressure.
5. Disconnect the negative battery cable.
6. Remove the fuel feed-pipe mounting bracket, and the quick release fitting covers. (clean them if they're dirty so you don't get dirt in the system.
7. Put a rag or shop towel over the quick release fitting, then disconnect it.
8. Attach the fuel pressure gauge.
9. Put the main fuel relay back in, reconnect the battery, cycle the key to the ON position (II) until the gauge starts reading pressure. The fuel pressure should be between 40 - 47 psi.
If the pressure isn't to spec, try replacing the fuel filter (it's part of the pump unit, in the tank) and pressure regulator, then recheck. If it's still not right, replace the fuel pump.
turbo sol
Nov 22, 2009 05:05 PM
Syndacate
Jun 22, 2007 12:40 AM
90jdmcrxdude
Jun 26, 2006 08:07 PM
89hbcivicguy
Mar 19, 2005 05:01 AM
PTR1
Oct 6, 2003 01:17 PM
