91 crx si wnt crank any suggestions why
I have power to everything else on the car..the only thing it looks like to me is the starter>>it wnt crank...when i would try to strt the car a click noise would come from the relay behind the climate control and stereo...
click noise = starter. try pop starting it or jump the starter terminals with a scewdrive if you really really have to drive it. Pop start would be your best choice..
Well, its a jdm single cam zc swap>>all wires are hooked up right...no popped fuses..im using a 89 eengine harness..but the under dash harness is for the 91 crx si...does that make a difference....theres only one ground wire to the thermostat
beco
19
Mar 26, 2022 10:08 AM
Yuta
Jun 28, 2014 12:52 PM
