Stroked B16's 2cents.
Whats the most a stroked b16 can make with theses specs..
IF YOU HAVE A COMMENT LIKE " Why not go b20, b18, GSR, TYPE R, Etc. You will be ignored." Please keep topic relivant. If not just hit back button or pm trash talk..
IE. If someone has a stroked b16, what kind of numbers you make? track and dyno...
STROKED B16 1.858l
B16 block 81.5mm
Type r crank
12:1 Custom raised wrist pin piston For stroke
Shaved b16 rods For fitting in type r crank
Main studs
head studs
golden eagle girdle
Head B16
PORT AND POLISHED
skunk 2 springs
skunk 2 retainers
skunk 2 1mm over vlaves
Skunk 2 STAGE 2 Cams
Skunk 2 Cam gears
Replica big tube header
Obx ITB's
3" vibrant exhaust
STROKED B16 1.858l
B16 block 81.5mm
Type r crank
Main studs
head studs
golden eagle girdle
Head B16
PORT AND POLISHED
skunk 2 springs
skunk 2 retainers
Skunk 2 Cam gears
Obx ITB's
3" vibrant exhaust
Poor choice of "header." Shaving the load carrying area of the connecting rod doesn't sound like a bright idea to me either. Try it and let us know how it works out for you.
C2Imports
23
Jul 17, 2005 11:43 AM
