help! misfire
Old Jun 6, 2011 | 06:30 PM
thatoneguy374's Avatar
Icon3 help! misfire
I have a 98 lude with an intake and exhaust that has a misfire on cyl 4 but only when its warm it comes and goes if i hit vtec a few times it acts up or if i cruise at a steady speed for too long it also acts up and trips th light. have tried plugs wires egr clean out vavle adjustment check the time swapped vtec solenoids changed o2s tried everyting i can think of. my friend also has a lude with intake and exhaust wih the same problem on cyl 1
Old Jun 7, 2011 | 04:14 AM
1GPlusSH's Avatar
Default Re: help! misfire
what kind of fuel are you putting in there?
Old Jun 7, 2011 | 09:34 AM
Johnnytech's Avatar
Had same problem on my 96. Replacing the distributer cap and rotor fixed it. If you have done that already it could be a bad fuel injector. I have 4runner that would get random misfires on cylinder bank 1. Problem would come and go. I replaced all ignition components, fuel filter and still had the problem. Replaced the fuel injectors and now it runs like new again. Good luck.
Old Jun 7, 2011 | 06:18 PM
i run 93 from shell same gas i ran in my 07 si with no problems. I did a compression test and the cyl with the misfire has low compression. im thinking it could be a bad valve. i have an extra complete head that im gonna have sent out to get decked and hot tanked then im gonna check the valves in it and install new valve seals and swap the head out hopefully that takes care of it. i have already replaced all ignition components and tried diffrent injectors off a friends car still the same problem.
Old Jun 8, 2011 | 12:47 PM
accordboi77's Avatar
I had a similar problem... It ended up being the distributor.
88 EF Hatch
Sep 25, 2009 11:57 AM
memphisfuk
May 19, 2008 06:48 PM
layinlowon14s
Mar 27, 2007 12:29 PM
Butler230
Jul 16, 2003 07:50 AM
