96 del sol fan problems
Old Jun 6, 2011 | 04:14 PM
freeloader587's Avatar
Default 96 del sol fan problems
I have a 96 del sol Si but now no vtech motor
my radiator fan wont turn on
I have checked the fan its self it works
I checked the fuse block and relay they are good
I ohm metered the wires to the fan plug and there good no shorts
The fan did work when I swapped the motor in.
only thing I different now is no condenser or ac pump
and 2 vetch plugs bare
not sure to much on these cars took me 2 days to figure out the fuel pump is power runs away then back to the pump
Old Jun 6, 2011 | 05:45 PM
virgineg6's Avatar
Default Re: 96 del sol fan problems
did you bleed the system correctly? the temp switch might be bad try jumping the connector see if the fan turns on. but make sure its bled correctly 1st
navila17
Jul 21, 2015 07:07 AM
Kush2Slow
Mar 8, 2014 05:52 PM
woahdelsol
Dec 31, 2012 06:25 PM
KYDelSol
May 31, 2012 02:15 PM
Michael Thomas
11
May 2, 2012 09:08 AM
