91 EF hatch dx k24a4 questions
Well i finally decided to do a K swap on my EF hatch and I just want a Daily Driver K swap for the moment and all i wanna know is what parts am i gonna need so i can have a reliable k24a4. I have searched and This is the list i have came up with so far:
ENGINE/TRANNSMISSION
K-series Engine (K20 / K24)
K-series Transmission (RSX-S / RSX Base / DC5 Type-R / Civic Si / EP3 Type-R)
K-series Engine harness (RSX-S 02-04 )
K-series Charging harness (RSX-S 02-04 )
K-series Alternator (Which one do i get for k24)
K-series Starter (which one do i get for k24 )
K-series ECU (RSX PRB 02-04) + Hondata K-Pro
CRV Passenger side engine mount (needed for non-CRV K24 swaps)
K20 Swap Header (DC Sports / Hybrid Racing)
Clutch + Flywheel (02-06 RSX-S)
RSX Type-S Oxygen Sensor (02-04 Primary)
RSX Type-S Knock Sensor (Only if not using RSX-S engine, or repin stock Knock sensor)
RSX BASE Axles Or...
RSX-S Axles w/ B-series 32mm Outers
Accord Throttle Body
Accord Intake Manifold
EF Engine Mounts (Hasport / Hybrid Racing )
Harness Conversion (Hasport / Hybrid Racing)
Clutch Line (Karcepts/Hybrid Racing )
RADIATOR/COOLING
(will this work using a stock Civic half-size radiator in my EF civic?)
Coolant Hose Adapter (MFactory / Hasport / Hybrid Racing) and re-use Stock B/D series Fan switch and coolant temp sensor
Mishimoto 10" Electric Fan
Mishimoto 1992-2000 Honda Civic SOHC Radiator (for half-size applications
TOP Rad Hose - Which do I use for EF CIVIC?
BOTTOM Rad Hose - Which do i use for EF CIIVIC/
SHIFTER PARTS
Karcepts Shifter mounting kit or...
Hybrid Racing K Swap Bolt-In Short Shifter
RSX Type-S Shifter Box (OEM / Buddy Club )
RSX-S 2002-2004 Shifter Cables (OEM / Hybrid Racing)
Shifter Parts to Connect Shifter Cables (OEM)
EXHAUST PARTS
Is there Any Out there for the EF
FUEL SYSTEM PARTS
What do i need for my EF Civic
WITHOUT AC
EP3 Idler pulley/bracket
Manual Steering rack
K24 = 52" Serpentine Belt
K20 = 50.5" Serpentine Belt
Fluids Needed:
Power Steering Fluid - 2 Bottles
DOT3/DOT4 Brake fluid - 2 Bottles
Coolant 50/50 Mix - 2 Bottles(3 to be safe/cover leaking or spillage)
MTF - 3 Bottles
OIL - 6 Quarts
If i want to get it bar'd will i need the RSX dash harness?
If i need it does it matter if it is the RSX typ-s or base model dash harness?
And if there is parts i am missing can you let me know and if there are parts i dont need to to have for a daily driver can you let me know...
RADIATOR/COOLING
SHIFTER PARTS
EXHAUST PARTS
FUEL SYSTEM PARTS
WITHOUT AC
Fluids Needed:
MTF - 3 Bottles
OIL - 6 Quarts
this is why im not doing my k-swap in an ef. don't have this much patience. you might can find some answers here. https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx89k20s-honda-story-so-far-2909134/
she has a great build and seems to be helpful with questions.
good luck!!
good luck!!
that i know of, if you run a k24 you wont be able to run a hood, my homie put a k20 in his ef and had to modify a sir hood and the passenger side headlight housing, then buy a bracket to re route the belt, he also had to modify the shift plate from a eg, he did get a sheet of aluminum and eventually made his own shift plate, as for the hood the k24 sits too high, i could be wrong, jus thought i would warn you
