b16 boggs after 30-45 mins of drvn on frwy
Old Jun 6, 2011 | 08:16 AM
ewok1's Avatar
Default b16 boggs after 30-45 mins of drvn on frwy
so sat and Sunday i drove my hatch and it started to bogg when comung home from a 35 min drive on the frwy..it will lose power then gain then loses bacj n forth..car is not overheatin all fluids r fine..what can it be need sum help. car is fine when. driven oń the streets..there was a lil back fire i heard as well..help plz
Old Jun 6, 2011 | 08:46 AM
ImportHatch's Avatar
Default Re: b16 boggs after 30-45 mins of drvn on frwy
Pull a plug and see what it looks like. My old truck used to do the same thing.
Cruising at a low load while running rich would eventually foul a plug and do exactly what your saying.
Old Jun 6, 2011 | 09:00 AM
ewok1's Avatar
ill check it..thanks bro
Old Jun 23, 2011 | 06:15 AM
ewok1's Avatar
so i changed spark plugs and wires and still the same thing. i drove for a 40 min drive and it started to lose power then gain again only when stepping REALLY HEAVY on the gas,but it feels like its holding back,then out of know where it will run fine again,then back to loss of power WTF can it be?
Old Jun 23, 2011 | 10:07 AM
rpmraper's Avatar
sounds like an 02 sensor to me...
Old Jun 23, 2011 | 10:17 AM
hondaluver19's Avatar
^^^ agree. And make sure your belt on your alt. is tight. I've seen the alt. belt loose and still turn the pulley but not the way it should be charging, if you could understand that. Lost my train of thought on that.
Old Jun 23, 2011 | 10:22 AM
ewok1's Avatar
why would that cause the off and on loss and gain of power?
Old Jun 23, 2011 | 10:35 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Obviously the alternator is slipping you lose voltage - depending on load needs it could affect performance. Most cars are designed to operate on 13.5 ~ 14.7 volts... So if you go from that to slipping under 11-12v there is a problem.
From your first post, you gave a horrible description, so it makes it hard to help you. This is on top of your horrible grammar and sentence structure.
Old Jun 23, 2011 | 10:44 AM
ewok1's Avatar
k,so if voltage is being loss would my head lamps and instrument lights be dimming while this is happening?
Old Jun 23, 2011 | 10:47 AM
4drEF's Avatar
Keyboard Humorist
Any mods to the engine or emissions?
Do you get a CEL when this happens?
Old Jun 23, 2011 | 10:57 AM
ewok1's Avatar
bone stock swapp...got a CEL twice but it went away both times
Old Jun 23, 2011 | 11:29 AM
yes and no. depends how loose the belt is. but when you are losing power, your lights would be dimming at the same time.
And another thing I just remembered, it happened to my moms accord. She was losing power every now and then, turned out one of the spark plug wires was faulty. The metal contact inside the wire that clips to the plug broke and would lose contact some times. But it might be something worth checking out.
Old Jun 23, 2011 | 11:31 AM
And what do you mean the code just went away? Did you clear them or did it just never come back on? Did you ever get the codes read?
Old Jun 23, 2011 | 11:35 AM
ewok1's Avatar
Cel Went away didn't get the code
Old Jun 23, 2011 | 11:39 AM
ewok1's Avatar
the. belt is fine going to check thespark plug wires again bro. thanks
Old Jun 23, 2011 | 11:41 AM
I would first check to see if the alt. belt is loose. If not, get a multimeter and check the voltage coming from the alt. to the battery. And take a look at your O2 sensor too.
Old Jun 23, 2011 | 01:50 PM
91siRjdmMob's Avatar
mine was doing the same thing...
turns out the alternator ended up giving out and got me stranded..
get it checked...
Old Jun 23, 2011 | 09:58 PM
~sp33~'s Avatar
EFB055
Same thing is happening with my EF, :/ Replaced a heap of sensors with no prevail yet. Let me know if you work it out!
Old Jun 23, 2011 | 11:34 PM
SuicideError's Avatar
Im not sure if this relates but I had somewhat of a similar problem. There was times where I accelerated and got no response for a second as if losing power then it would work fine. So while the car was running I moved around the wiring that goes from the main harness to the distributor and it would try to turn off.
I bought an electronic cleaner to spray both plugs to the distributor and redid the wiring.
Its been working good ever since.
Old Jun 23, 2011 | 11:38 PM
RTcivicSi's Avatar
Mine does the same thing sometimes after 30 minute drive, it will bog at about 3-4,000 rpms then I would have to floor it to drive normal. If it is alternator, is it possibly damaged from getting wet(driving over puddle).
Old Jun 23, 2011 | 11:51 PM
i doubt it could get damaged with a little water while the car is running.
Old Jun 24, 2011 | 02:58 AM
DO IT ON ALL FOURS
Sounds more like O2 sensors either being disconnected or switched around.
Old Jun 24, 2011 | 03:59 AM
Aftermath_Hatch's Avatar
Ok guys hear me out I had the seem problem twice already,I would lose power after I drove a lil and the power would come back off and on,my friend I put money on it your distributor is about to take a ****.When your boggin down it's because your lose fire from one of the cylinders caused from the distributor. Have one of your plug wires popped off yet?
Old Jun 24, 2011 | 04:06 AM
DO IT ON ALL FOURS
It could be the ignition module is taking a crap. I was thinking you just did the swap...
Old Jun 24, 2011 | 04:54 AM
ewok1's Avatar
i get paid tody gonna go buy an o2 sensor and take it to my mech to check out my alt. ...also gonna return my sparkplugs n see if they were faulty ones..let u guys know how it goes later
