95 accord, hood won't pop open
Old Jun 6, 2011 | 07:41 AM
j4s0n1337's Avatar
Default 95 accord, hood won't pop open
I'm guessing its the hood latch cable, since the hood release lever has no tension. Question is, how do I get the hood open so I can make the repair?
Old Jun 6, 2011 | 02:38 PM
jamzx3's Avatar
Default Re: 95 accord, hood won't pop open
my car does the same thing and i havent fixed it....you'll need an extra set of hands....whoever has the smaller hands needs to feel around for the cable at the front of the hood and put tension on it....then they other person needs to pull the lever and voila hood is open...
Old Jun 7, 2011 | 10:31 AM
j4s0n1337's Avatar
I think i can just unbolt the latch mechanism, might have to cut the grill a little bit but i think i can get it. Could i get a new cable from the junkyard or would I be better off buying a new one?
Old Jun 8, 2011 | 11:45 AM
nus_dogg's Avatar
Just use a needle nose pliers to pull the hood latch open. You do this by using a needle nose pliers and get behind the hood latch and grab it by the cable wire and pull on it, this will pop the hood open. Done it many times at work.
I recommend you replace the hood cable as it has been stretch; hence, why there's no tension on it when you pull the hood latch lever.
Old Jun 8, 2011 | 02:14 PM
j4s0n1337's Avatar
BINGO!
I'll be picking one up from the junk yard tomorrow. Has anyone done this before and can give me some tips? I'm guessing just follow the cable so I know where to install the new one, but some pictures would be nice =D
Old Jun 8, 2011 | 02:21 PM
j4s0n1337's Avatar
What other cars use the same size hood cable?
Old Jun 8, 2011 | 02:36 PM
phootbag's Avatar
Just get the right part. Even from the dealer I don't think it's too expensive. Chances are, the retainer that holds the sheath has come out of it's fork shaped mount. This keeps the cable from being able to pull on the mechanism.
Old Jun 8, 2011 | 10:57 PM
j4s0n1337's Avatar
Is this fixable? i'll probably go to the dealership tomorrow
Old Jun 9, 2011 | 02:59 PM
phootbag's Avatar
They'll charge a lot for the labor. The other option is to do it yourself. You will then discover why they charge a lot.
Old Jun 12, 2011 | 08:27 AM
j4s0n1337's Avatar
Sweet.....not really, the local Honda dealer just called me and said my new cable was in so imma get that today. Does anyone know of a write up or can give me some advice on how to change the cable?
Old Jun 12, 2011 | 04:08 PM
phootbag's Avatar
The cable is routed from the latch, through an opening above the headlight, between the inside of the drivers fender and unibody, passes through a hole in the body to a point around the drivers kick panel.
When replacing the cable don't just rip the old one out. Connect the old cable with the new cable so as you pull the old cable out, you are also pulling the new cable into place. Make sense? It's a pain in the *** if you don't use the old cable to pull the new cable through. Trying to route the new cable by itself is a pain.
Old Jun 12, 2011 | 08:00 PM
j4s0n1337's Avatar
Will this damage the new cable at all? I know its a dumb question but I get super paranoid some times
Old Jun 13, 2011 | 10:36 AM
j4s0n1337's Avatar
just use some tape? I just want to make sure I do this right the first time y'know?
Old Jun 13, 2011 | 01:49 PM
phootbag's Avatar
As long as the joint between the two cables is relatively smooth it shouldn't catch on anything.
Old Jun 13, 2011 | 01:59 PM
93accordlxwhite's Avatar
Yeah it's basically like running a bicycle brake cable, just one cable inside a sleeve to prevent friction.
hondadude567
Oct 12, 2008 12:57 AM
boostedhks
Jul 24, 2008 07:45 PM
blueaccord94
Mar 26, 2005 07:53 PM
scrolanky
Jan 21, 2004 05:21 PM
