Rear Wheel got very hot
Old Jun 5, 2011 | 10:48 PM
RDAYA0's Avatar
Default Rear Wheel got very hot
Got home from driving tonight and I noticed a burning smell. Got out and checked all 4 wheels and my driver side rear wheel lug nuts were hotter than the rest.. seized caliper or e brake stuck? help pls..
Old Jun 5, 2011 | 11:49 PM
vtecdc4's Avatar
Default Re: Rear Wheel got very hot
seized caliper
thats what mine was
Old Jun 6, 2011 | 03:52 AM
fcluddington's Avatar
X2.
Old Jun 6, 2011 | 05:49 AM
fcm's Avatar
fcm
Old Fart
X3, or wheel bearing on it's way out.
Question, do you always use your hand brake? 94
Old Jun 6, 2011 | 05:57 AM
GagnarTheUnruly's Avatar
Could also be a clogged/failing brake hose.
Old Jun 7, 2011 | 09:23 AM
legend97's Avatar
most likely its a siezed caliper
Old Jun 7, 2011 | 05:14 PM
RDAYA0's Avatar
Yup seized caliper looks like this corner wasn't replaced by the last owner, got a new caliper install went smooth but i broke the banjo bolt that holds down the brake line to the caliper.... anyone know where i can get one fast? or if they can confirm if they are the same bolts for the front or if any banjo bolts that are on civics work? please and thanks.
Old Jun 7, 2011 | 05:29 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
On a 94 Teg front and rears are all the same... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal and they are the same as the ones on a 94 Civic... http://www.hondaautomotiveparts.com/...+LINES+%281%29 94
Old Jun 7, 2011 | 05:38 PM
RDAYA0's Avatar
96 integra 2 door rs
Old Jun 7, 2011 | 05:41 PM
RDAYA0's Avatar
thanks for the info
Old Jun 8, 2011 | 06:12 AM
fcm's Avatar
fcm
Old Fart
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal also the same. 94
whitegsr-t
Aug 15, 2008 04:23 AM
Nisif
20
Sep 26, 2007 07:04 AM
Jon V
87
Sep 28, 2006 11:09 AM
slooogsr
Oct 13, 2004 03:23 PM
cccya
Oct 25, 2002 06:06 PM
