civic swapped jdm h22a
Old Jun 5, 2011 | 01:37 PM
d601's Avatar
Default civic swapped jdm h22a
its a 96 civic with jdm h22a. AND THE DAMN VTEC IS NOT KICKIN IN!!! this just now started happening today. someone told me to replace the screen and gasket inside th vtec syloniod but i would like some more references b4 i start gettin into a money pit. Respond asap plz!!!!
Old Jun 5, 2011 | 06:53 PM
slammedbbs's Avatar
Default Re: civic swapped jdm h22a
add a turbo turbo then your vtech will pop lol hard! i wish i could help you, all i no is it works off oil pressure. maybe check your oil pressure and oil lvl?
Old Jun 5, 2011 | 07:23 PM
nus_dogg's Avatar
Is your oil level low? Do you have a big dent on your oil pan?
Old Jun 5, 2011 | 07:38 PM
d601's Avatar
Oil level is good, no dents. This only happens very seldom, only wen the car has been runnin for 45+ minutes. Otherwise it kicks in like hell.
Old Jun 5, 2011 | 08:59 PM
slammedbbs's Avatar
that is strange when you find out let us no!
Old Jun 6, 2011 | 06:02 AM
typemismatch's Avatar
Honda owns me
Are you OBD1 or OBD2? Do you have any CELs?
It seems, one of the first things the ECU takes away when there is a CEL is VTEC
Old Jun 7, 2011 | 06:19 AM
d601's Avatar
its an obd2 car with an obd1 motor and ecu
no CELs i believe
Old Jun 7, 2011 | 06:35 AM
Honda owns me
Does your radiator fan come on? What harness are you using?
I converted an F22 harness when I did my swap and didn't have the fan switch plugged into the front water neck, because my H22 didn't come with that sensor. I ended up swapping the F22 water neck with the sensor onto it and that did the trick.
I would get a CEL and VTEC would stop working after 20 minutes or so.
Old Jun 7, 2011 | 08:23 AM
slammedbbs's Avatar
thats crazy lol this is my first honda and vtech seems to be a pain in the *** for alot of people. iam glad i have not had any problems with mine! (knocks on wood)
Old Jun 7, 2011 | 09:01 AM
d601's Avatar
ya man my fan cuts on as it should. and this only happens very seldom. My best guess is the screen inside the soleniod. but if it was clogged shouldnt it not work all the time??
Old Jun 7, 2011 | 06:48 PM
Honda owns me
Not sure what a dirty solenoid would do, I haven't run into that problem yet.
How about your speedometer? Does that work all the time? If your VSS is going bad it may cut in and out.
I think the main things that determine VTEC engagement in the ECU are vehicle speed, engine speed, engine temp, oil pressure and ECU running mode, normal or limp.
If any of the sensors reporting to the ECU are malfunctioning, "VTEC don't kick in yo!"
Old Jun 10, 2011 | 09:12 AM
bcon07's Avatar
Vtech is a phone
Vtec is for your honda
Old Jun 10, 2011 | 09:30 AM
slammedbbs's Avatar
lol hahaha thats funny as hell good call man i didnt catch my self doing that.
Old Jun 10, 2011 | 04:31 PM
d601's Avatar
lol i have always noticed people doin that wen most of em have it written on there motor
Old Jun 12, 2011 | 07:28 AM
EG8_DOHC-VTEC's Avatar
yea man definitely check your vss on da back of da tranny..... if it's malfuctioning ur assed ouut on vtec.... and also check computer for trouble codes 19 and 21... u might have an auto ecu.
jordan_rael_420
Sep 11, 2008 08:36 PM
quickv8s10
Aug 5, 2007 12:06 PM
951dc5
Mar 27, 2007 11:20 AM
nelsond
Dec 11, 2006 05:13 AM
