Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why is My Power Window Function Not Working?
Guide to diagnose trouble and recommended solutions
98 civic lx 4dr power windows problem
just bought me a 98 civic lx 4dr and the power windows dont work. well the passenger rear does but the other 3 dont. i checked the fuses and they all was good i even try swapping them around. any suggestion?
need some help..ty ht
i did it the way where you would unplug that certain plug on the door and connect it to the battery with a ground and power wire, the 2 plugs prung whatver its called. i did that and it didnt work so i assume it was the motor. it was just the driver side i tested to.
i also found out that i can roll down the rear passenger window with the driver control but when i press it on the rear passenger window it doesnt work. and as you know the other three doesnt work rather i use the driver control or not, or if i press it at there own button.
so im pretty lost
so im pretty lost
work your way down from the fuse box then check for power and ground at the switches if thats good the check the plug that goes to the from the door to the regulator if thats good then check regulator
Newhondawhothis
Feb 18, 2018 07:40 AM
hondahustle
Jun 12, 2012 06:04 PM
