wiring up vtec on a d15z1
My buddy has a 92 civic which had the d15b7 but blowed it up and bought a d15z1 and I put it in for him and used the wiring harness for the z1 and the ecu so I just need to know how to hook up the vtec?
if you used the z1 harness(which is vtec-e) then it should already have the plugs for the vtec solenoid, which in turn should plug right into the ecu, and you should have vtec... if you didint use the z1 harness, its only a few wires you ned to run to the ecu, and a ground
Well is there a different ecu that will help it? I mean I know there isn't much help with the z1 it being an economy motor but it should have better power than the b7 and it doesnt
rorik
Engine Management and Tuning
Jun 14, 2008 05:36 PM
F5sGsrHatch
Mar 22, 2007 08:06 AM
