Possible vacuum leak
Old Jun 5, 2011 | 01:23 AM
91b18a1ls's Avatar
Default Possible vacuum leak
Yesterday I installed a Hondata intake manifold gasket and everything was working great last night and earlier today, but I drove to our local car meet tonight and when I got there I noticed the idle was bouncing up and down. I have the idle set to 900 and what it was doing was slowly going up to 1300 and then it would drop back down. It doesn't seem like a vacuum leak cause it doesn't go all crazy, it just creeps up to 1300 and drops back to 900. It will do it for a few minutes and then go away and act fine, but then it comes back a few minutes later. It also doesn't do it when I turn my a/c on for some reason. When the a/c is turned on it idles fine.
This is the driving i did today, I pushed the car pretty hard hitting my rev limit (8200rpm) a few times cause I was messin' around and after I did all that it was fine and acting normal. When I drove to the meet tonight I floored it in 5th and went about 110 (5500rpm) and after i did that is when it started acting weird. So I think a sensor might of come loose or maybe a loose connection. The car acts fine when i'm driving it and doesn't appear to have a vacuum leak.
Any ideas on what this issue could be? Thanks guys
Old Jun 5, 2011 | 02:25 PM
dc2sir's Avatar
Default Re: Possible vacuum leak
Idle Air Control Valve?
Old Jun 5, 2011 | 02:45 PM
91b18a1ls's Avatar
Wouldn't that cause it to happen all the time? I checked it and the hoses are still attached and when i took the intake manifold off i cleaned the iacv too so it should be good
Old Jun 5, 2011 | 06:46 PM
el crapitan's Avatar
with the car running, just spray starter fluid around the areas you suspect. when you spray the spot that causes the idle to act erratic, you've found your leak
a likely cause is that one of the lines which was removed/moved when installing the intake gasket may now be leaking. a lot of times these old lines don't like to be disturbed
dhabell
Oct 2, 2013 11:18 PM
HIallday
Sep 13, 2011 10:34 PM
93SiPrelude
Feb 24, 2008 10:39 PM
inane
10
May 19, 2007 05:36 AM
Concept Tuning
Apr 28, 2006 08:28 PM
