88-91 92-95 96-98 civic performance and OEM parts also parting a 97 civic ex
I have a ton of parts and a 97 civic to part.The car itself is a 97 ex 5 spd that was smashed really bad in the front so no front end stuff and most of the inside front like dash etc is destroyed. The engine and trans are sold along with the trunk. I'll list everything else I can think of, anything thats not listed ask about and I'll give you a price. I'm available 8am -430 thur and fri every other day from 7-9 pm in Hesperia. I work in Perris so i can meet you there or just off the 215 after 430 mon-wed as long as the part fits in a sentra. Text is the best way to get a hold of me or call after 6 till9 pm. Verizon sucks with texts lately so if I dont answer your terxt text me again. Robert 760 699 4579
TRADES looking for obd1 civic or integra ecus or factory stock civic cat convertor eitgher under car or part of the exhaust manifold
Performance parts
96-98 AEM TRU time cam gear red 40
92-95 Skunk 2 cam gear grey looks new 60
AEM cold air intakes with filter for 92-95 civic 96-98 civic and 99-00 civic si all have the carb numbers and filters 80 each
Y7 intake with filter for TB mounted in the middle 20
Password JDM lightened and slotted flywheel 100
Y8 intake manifold complete ready to bolt on 70
d series stainless header scrapped a littl eon the bottom 40
d series stailess header scraped good and dented on the tubes 20
slotted ex brake rotors 20 for both
dc b series 4-1 header scrapped on the bottom 80 with carb number
Hedman Charikara header in great shape carb legal 80
chipped and converted to p28 vtec obd1 p06 ecu with either b series or d series chip with launch control cel shift light increased rev limiter and upgraded maps 100
p28 stock ecu 5 spd 80
complete h22 head 200
88-91oem parts
stock si or hf distributor missing two wire round plug 40
stock dx dual point rebuilt distributor also missinmg wire round plug 30
complete dual point intake manifold 25
pm8 hf ecu 30
92-95 OEM parts
vtec e long block untested spins good never installed 120
p28 5 spd ecu 80
p07 5 spd california edition ecu 50
ex exhaust manifold 20
stcok coupe or 4 dr tailights 10 each light
ex auto cluster with tach 30
stock d series clucth with pressure plate almost new 30
Transmission auto ex and dx models 120
complete power steering system rack and pinion pump all lines etc 80
rear bumper white or green 30
96-98 cvic oem parts
Factory optional CD player fits where the lower tray is and plugs into the factory radio 40
coupe rear tailights 40 for all 4
rear seats grey 20
power steering rack and pinion and lines 40
master cylinder 20
all 4 stock struts and springs 80
ex brake calipers 20 each
drivers side spindle 25
p2p ecu 5 spd 30
y8 complete manifold 70
y8 auto complete manifold greta upgrade for y7 motors 40
y8 and y8 distributors 50
drivers side mirro power and white 20
anything else ask about on the ek part out thanks
Robert 760 699 4579
Performance parts
88-91oem parts
pm8 hf ecu 30
92-95 OEM parts
p28 5 spd ecu 80
rear seats grey 20
master cylinder 20
p2p ecu 5 spd 30
Robert 760 699 4579
