which map sensor do i use??
hey guys,i have a 93 lx sedan and just swapped in a d16z6.Now the car originally came with the map sensor on the firewall and now the d16z6 has a map sensor on the throttle body,which would you recommend to use,wiring harness for the engine is a z6 andfrom the 3 connectors to the ecu is the stock lx,thanks h-t
Brumeh
Jun 7, 2013 06:30 PM
