Header coating
Old Jun 4, 2011 | 08:07 PM
KraZyCHOWMEIN's Avatar
Default Header coating
Ran a search and it looks like most of the threads are from pre 2006. My hytech header is off the car because I needed to go to a test only facility (damn CA). Now that the header is off I figured it would be a good time to get it jet hot coated or Swain coated. What I'm trying to do is avoid shipping the header out.
Anyone in NorCal know of a reputable facility to have the header coated properly?
Thanks!
Old Jun 4, 2011 | 08:26 PM
racebum's Avatar
Default Re: Header coating
google ceramic coating your city, high temp coating your city, jet hot your city,
variations of that with your city at the end of the search phrase will pull up a ton of results
Old Jun 5, 2011 | 08:20 AM
Tomcat's Avatar
I used to like the black thermal barrier header coatings from HPC, but I've had problems with the coating flaking off on the outside of the header twice now.
Old Jun 5, 2011 | 09:08 AM
FlewByU352's Avatar
What type of coating can be used to keep it shiny? I see that nitrate coating that keeps it shiny kind of turns goldish color with the purple, green, and blue heat fading but I have no idea who does that and I tried searching.
Old Jun 5, 2011 | 02:56 PM
SlapSmak's Avatar
Jethot Coating. Looks like this:
Old Jun 5, 2011 | 04:47 PM
racebum's Avatar
you coat a used header? if so that's likely the problem. you either have to sand blast and etch a used header or coat a brand new one
Old Jun 5, 2011 | 05:15 PM
That jethot coated header looks great! Too bad there isn't a local dealer around here
96hatchBoy
Oct 26, 2012 09:14 AM
RedneckRicer
Apr 3, 2008 12:05 PM
Bigjussin
Sep 16, 2004 03:37 AM
Buzzbomb
Oct 6, 2003 05:01 PM
ITR 01-0840
Apr 25, 2002 05:01 PM
