1992 integra with obd0 b18a1 in it ( help )
Old Jun 4, 2011 | 02:10 PM
trigger_time's Avatar
Default 1992 integra with obd0 b18a1 in it ( help )
ok i have put a obd0 b18a1 in a 1992 obd1 integra i have gotten the following stuff distributor obd1 ecu which has been socketed for a chip and supposely has a make shift chip programmed in it now .. the engine has been built to factory spec except for the valve train which has a complete brain crower package installed on the head itself . running stage 2 crower cams on this engine .. had it running and it was running at rough idle . seems as if once you gave it gas it would cut out also have a new walbro pump , blox fuel pressure regulator on it now when you turn the key the car will not start . turns over fine but not starting . i noticed a buzzing sound from behind the intake manifold which is also aftermarket obx style. unplugged i guess you would say is the idel air control unit and no more noise .. whats going on here , also ideas on correct injectors and whether or not a resistor box is needed . need some answers guys . thanks
trigger_time
Jun 8, 2011 10:03 PM
clubef9
Oct 4, 2007 07:15 PM
LSV_REX
19
Feb 13, 2006 05:52 PM
