Honda CR-V & Element 2WD & 4WD Element & CR-V
Honda CR-V Transmission Fluid Recommendations
Old Jun 4, 2011 | 12:57 PM
jjager13's Avatar
Default Honda CR-V Transmission Fluid Recommendations
i have a 2001 honda CR-V and i was told that i should only use honda fluid in the trans. is this true? if not what other options do i have that will work. thanks in advance.
sorry forgot to add its an Automatic.
Old Jun 4, 2011 | 02:27 PM
nathan8210's Avatar
Default Re: Honda CR-V Transmission Fluid Recommendations
I always use OEM fluids. Why would you want to use something else? Unless you had a 5sp tranny and it was grinding i would understand why you would want to try something else. Is it 5sp or auto? If you have no tranny issues I would stick with OEM
Old Jun 4, 2011 | 07:25 PM
slowcivic2k's Avatar
There are a lot of compatible fluid out there for the automatics, most independent shops use a variant of Dexron III that is compatible with most everything. But for the sake of correctness, use a Honda ATF, its what Honda wants in it.
Old Jun 4, 2011 | 09:41 PM
davija's Avatar
Honda does say you can put Dexron III in the auto tranny in a pinch, but they do recommend that you drain and re-fill with honda ATF as soon as possible if you do need to do that. I'd stick with Honda ATF unless you don't have any other options.
Old Jun 5, 2011 | 06:52 AM
Mechanic's Avatar
This subject has been discussed extensively on crvoc.com. The weight of authority is OEM (purchased online to save $).
Jaydeep
28
Dec 20, 2011 07:23 AM
greenskittle
May 14, 2010 12:05 AM
scuzz
10
Jan 29, 2010 03:44 PM
cdansl
Jul 2, 2005 05:30 PM
JMD
Dec 24, 2003 06:22 PM
