Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 Civic EX P1259 CEL Code
Old Jun 4, 2011 | 07:32 AM
callinthe187's Avatar
Default 2003 Civic EX P1259 CEL Code
Hi Guys
I just purchased a 2003 Civic EX and the CEL light was on, when i got home I checked the CEL code and it was P159 Vtec System Malfunction.
I did the following:
Removed the solenoid to inspect the solenoid filter (it was as clean is it comes)
changed the oil pressure switch located on the vtec solenoid (with a dealer switch not aftermarket)
once i did this i pulled the ecu fuse to reset theCEL, started the car and in Neutral or Park once I rev the car it won’t pass 4k rpm. I drove the car for about 15-20 minutes with no problems, then CEL code came back and won’t pass 4k rpm.
What can it be I am going crazy with this
Old Jun 4, 2011 | 09:09 AM
lazlong's Avatar
Default Re: 2003 Civic EX P1259 CEL Code
Did you check oil level?
Old Oct 10, 2011 | 01:36 PM
GlinianyT's Avatar
I have this exact same thing going on. Redlining at 4k RPM and now it is bogging down at 2k RPM so i'm thinking the Vtec solenoid is completely shot. Oil pressure is good engine temp is good.
Anyone have suggestions on where to purchase a new one other than the expensive dealer. Honda recommended a Spool Valve for $241 I saw Vtec solenoids on ebay for $75
Old Oct 10, 2011 | 04:31 PM
lazlong's Avatar
Number 9: https://www.hondapartscheap.com/inde...SOHC%20VTEC%29
Old Oct 10, 2011 | 09:12 PM
jdmdv's Avatar
this happen to me the other day, but check your oil level like mention above, changed oil and good ever since
Old Oct 12, 2011 | 05:01 PM
exb18c1's Avatar
Originally Posted by callinthe187
Hi Guys
If the VTEC oil pressure switch doesn't see specific oil pressure(i think around 55psi it will not allow the ECM to activate the VTEC function.Check the oil pressure.
tamadrummer1120
Sep 17, 2009 09:20 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
ninety9ex
Jan 26, 2004 07:40 PM
JohnnyBoy
Dec 6, 2001 08:54 PM
