b18b swap -shifter lever arm problems
Old Jun 3, 2011 | 11:56 PM
Jhonpebz's Avatar
Default b18b swap -shifter lever arm problems
hey everyone i got a 89 crx si with a b18b swap and b16 cable tranny that im working on.so far i have everything bolted down and everything plugged in.
i tried to give it a start but thing just turns over and over but wont start.so i called a couple buddies to give my crx a push so i can push start it.I shift in to 2nd with my foot on the clutch and gave them the wave to start pushing but car wont budge even when clutch pedle is pushed in all the way.the only time the car moves is when its in neutral.i even tried to start it with my foot on the clutch pedle and shifted in to 1st gear and when i did that the the car moved forward like you'd start a car without pushing on the pedle while in gear....
i notice that the shifter lever arm on the tranny wasnt fully extending a!!!anyone know what this could be?i hope i gave a clear view of whats going on....i need all the help and info i can get fellaz....
Old Jun 4, 2011 | 12:47 AM
ef yu's Avatar
Default Re: b18b swap -shifter lever arm problems
try adjusting the cable or use one from an integra
Old Jun 4, 2011 | 07:55 AM
Jhonpebz's Avatar
I did that a hole bunch of times but the arm on the tranny won't fully extend...
Old Jun 7, 2011 | 12:17 AM
Jhonpebz's Avatar
Is it possible that because I used a hydro clutch instead of a cable clutch, could be the problem?
Jhonpebz's Avatar
Help anyone
Old Jun 7, 2011 | 09:14 AM
ef yu's Avatar
Originally Posted by HandCommand
All B-series trannys from 92+up will use the CLUTCH DISC with the Bigger spline.
The 90-91 B-series trannys will use the CLUTCH DISC with the smaller spline, because they have a smaller input shaft.
All B-series Pressure Plates will be the same no matter if its CABLE or Hydro.
ThrowOut Bearings will be different between a CABLE tranny and a HYDRO tranny.
Jhonpebz
May 20, 2011 07:41 AM
sonic47
Dec 5, 2008 11:52 AM
TouringAccord
81
Sep 27, 2006 03:39 AM
slow91crxdx
Sep 4, 2006 08:38 PM
Lo-Buck EF
Apr 28, 2003 06:56 PM
