All Motor 1.8L HELP..!
so i basically have a stock jdm itr motor wit twm 50mm itbs, skunk2 flat face valves, skunk2 pro1 cams, skunk2 pro series valve springs and retainers. Lookin for some decent headers to go with, something like DTR, Bisimoto or smsp b19. But i cant seem to decide. I wanted to get the car tuned on e85, so do you guys think 440 injectors will be okay.? The bottom end is completely stock. Also thinkin bout get the car tuned at churchs or bisimoto... Just lookin for everyones advices, thanks
If you go to a reputable shop and/or buy reputable custom headers, you can't really go wrong. There really is no single best anything, more of a "group of the best". Buy from any of them and you can't go wrong.
What exhaust are you running? If you go with one of those custom headers, you should consider going to a 2.5-3" exhaust. I had a JDM ITR 4-1 header w/S2S2 cams and the dyno graph was smooth as glass at the VTEC crossover. When I swapped the header for a DTR 4-2-1, hp and torque both took a dump at the crossover. We had to raise the crossover to 6700rpm before we could get a smooth transition.
Fast forward 9 months later, I have a 84.5x89 GSR block, S2P1 cams, same header, 60mm APEXi WS2 exhaust and guess what...same thing. It made more power than before, of course (210 whp/145 tq), but there was a BIG dip in hp and torque at the crossover. It's still set high (about 6500 rpm). Came to find out dropping the exhaust let us drop the crossover back to 5K-ish and made 10-15 whp and 15-20 tq with absolutely no tuning changes. With tuning, with would have been more.
Will be putting a 3" on next month, retuning and expect to hit 230/165.
fm
fm
True. I think imma go with the bisimoto or dtrs.. But I'm leaning toward bisimoto.. Do ou think. The pro1 are too big for this set up..?
[QUOTE=fungus mungus;45400503]What exhaust are you running? If you go with one of those custom headers, you should consider going to a 2.5-3" exhaust. I had a JDM ITR 4-1 header w/S2S2 cams and the dyno graph was smooth as glass at the VTEC crossover. When I swapped the header for a DTR 4-2-1, hp and torque both took a dump at the crossover. We had to raise the crossover to 6700rpm before we could get a smooth transition.
I won't be running an exhaust, I rarely drive the car. It's been down for three years, just got it back a couple of month ago from the paint shop. It's my show car that I'm building. Shouldn't went k but I got suckered in on the itbs and swap for cheap. And where did you get the car tuned at..?
If you're running open header, you'll be fine with any of the custom headers. I got my car tuned at Blacktrax, but when it was an essentially stock GSR swap, I had it tuned there, DNR, and at DSR. DNR's dynojet read about 7% higher than Blacktrax's dynapak. DSR's dynojet read about the same as Blacktrax's dynapak. DSR got more power out of the 1.8l but the car ran smoothest on Blacktrax's tune.
fm
fm
Lsvtecy0
Jul 28, 2018 08:49 AM
landon1405
Aug 9, 2011 12:10 AM
HyperFlow
30
Oct 5, 2010 07:12 PM
PYITR821
Jan 16, 2003 06:32 PM
