B16a cable tranny
***** $250 for B16 trans****
I have a b16a cable trans for sale. I put a OBX lsd in it, but there was too much runout and I have not used it at all since the install. The trans worked fine , but it did have a slight grind once in a while going into 3rd gear. I had this in my crx for almost 20k miles and daily drove it and didn't beat on it. The gearing is just to short and I ended up building an LS trans for my car for highway cruising. I dont have the factory diff anymore since I used it in my LS. This would be a great trans if you just want to put in a good LSD or just put a stock diff back in. I just have one crappy pic but have more. I have 2 engines and 3 transmissions in my garage and need to get rid of some of this stuff. MAKE A REASONABLE OFFER!!!
Trans on top is the B16. The one on the bottom is an LS that I am saving for parts unless someone really needs it ( it has a tiny hole in the bellhousing that was fixed with JB weld)
Uploaded with ImageShack.us
It needs a new differential. It has a brand new OBX LSD in it but the diff has too much runout (not machined properly and would cause wobble at high speed). You could put a Type R lsd in it and be good to go. It is easy to do but I dont have the time or money.
why would that be? couldt you return it? would the lsd diff work in another transmission no prob or is it totally wasted? is it the ring and pinion setup or the lsd itself?
BUMP for anyone looking for a b16 trans. I haven't even gotten an offer yet....
