O2 sensor
Old Jun 3, 2011 | 04:23 PM
90efzc's Avatar
Default O2 sensor
Anyone have a how to on how to rewire/replace the O2 Sensor (near header) on a sohc ZC.
My o2 sensor sometimes fails to sense itself and throws a code. I can jiggle the o2 sensor around a little and press it together and it'll be fine "for some time."
Do o2 sensors come with the wiring setups as well? Doubting this.
Old Jun 3, 2011 | 04:29 PM
turbohatchBnuts's Avatar
Default Re: O2 sensor
Just solder a new connector on the exsiting wire in your harness where the o2 sensor is messed up. It should be one wire if your obd0 .
Old Jun 5, 2011 | 06:19 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You can buy an O2 sensor that has the factory style plug already on it.
