Purchasing a S2000: What to look for?
Hey Honda-Tech, I'm looking for a S2000 and found one on craigslist. I was just wondering what should I look for when I go to check it out? Any common problems with S2000 cars? Anything S2000 sellers try to hide from buyers? Any tips/advice would be appreciated. It's my first time looking at S2000s so I want to make sure that I cover every ground.
Here is are the specs:
2000 Honda S2000
Pink slip in hand
Smog ready
6 speed
112000 miles
Strong engine and transmission
Drives smooth and fast(feels like driving a go-kart)
Shifts smooth(the best gear box)
Reliable(its a Honda!)
no engine mod everything original
Ap2 soft top with glass rear(wear and tear but no issue driving in a rain)
Lowered with Tein springs(very smooth ride)
Carbon fiber front lip
Clean interior with no rip
Soft top with glass rear: has a normal wear and tear but I have no problem driving in a rain, water doesnt leak in. You can get the soft top for $300.
OZ Racing Superleggera Gunmetal Staggered 5x114 with fresh tires(70%)
18x8 +45 225/40/18 BF Goodrich KDW2 (6/32nds)
18x9 +45 255/35/18 Pirelli PZero (0-1/32nds)
F1spec ARC style shift ****
Pioneer CD player
Side diffuser
rear diffuser
Greddy exhaust
Salvage title due to rear end no frame damage
I bought it as salvage
$9500 with OZ wheels and tires
$8000 with AP1 stock wheels and tires
http://s1239.photobucket.com/albums/ff509/piandrewbae/
Any advice and tips would be great! Thanks!
2000 Honda S2000
Pink slip in hand
Smog ready
6 speed
112000 miles
Pioneer CD player
Side diffuser
rear diffuser
Greddy exhaust
engine cold start characteristics; CELs
transmission cold characteristics
compression/leakdown check
oil burning rate?
clutch condition, half shafts condition (if lowered or was lowered)
obviously any fluid leaks, seals, check for oil or corrosion in the coolant, or coolant in the oil cap
Timing chain tensioner
differential/rear end condition?
recalls/updates/TSBs - oil jets, retainer cracking
anything that indicates overrev or other abuse (launching), overheating
engine tranny serial numbers match up
oil burning rate?
First off, take it for a test drive. See if you like it. Then if the seller agrees, you pay to have the car looked at buy a reliable repair shop, 50 to a 100 now could save you thousands down the road.
On your test drive when you come to a stop let the clutch slow you down and see if it chatters, most of the early ones do if it hasn't been replaced. Clutch jobs on those are not the most fun.
Also take low speed turns and see if the rear wheel bearings r nosiey, most early models are. and have to be replaced.
One other thing, and it might just be me but how come all the pics are from the passenger side?
Hope i could be of some help.
Good Luck
Good Luck
Thanks guys. Tremendous help! I will definitely make a check list to look for those problems. Does any of the information that he provided seem sketchy?
Make sure that you thoroughly inspect the condition of the top as well on account that the S2k's top seems to wear quite quickly. Scrutinize the area displayed in this pic as I've seen a lot of S2000s with wear in this part of the top:
A few of my buddy's have temporarily rectified this issue by inserting a piece of cloth, foam or any other soft material in between the top frame/hinges and the vinyl itself. A cheap and short-sided fix, but hey- you can't complain about the price
2000 Honda S2000
Pink slip in hand
Smog ready
6 speed
112000 miles
Pioneer CD player
Side diffuser
rear diffuser
Greddy exhaust
2000 Honda S2000
Pink slip in hand
Smog ready
6 speed
112000 miles
Pioneer CD player
Side diffuser
rear diffuser
Greddy exhaust
Check the tensioner. Pull the throttle wire gently and give the valves a listen.
If it's been missed above definitely take a listen for any differential whine. When I was deciding between the AP1 and AP2 I found more early models with whiny diffs at low speeds. No big because the gears come out quickly for an upgrade though!!
