94 lude idle prob
Old Jun 3, 2011 | 11:46 AM
lilrobie69's Avatar
Default 94 lude idle prob
The starts and runs fine for first few mins then starts to bounch around idleing wise beed some tips. F22
Old Jun 6, 2011 | 09:15 AM
xtremelude94's Avatar
Default Re: 94 lude idle prob
How often does it do it? My lude used to do the same thing. Typically a bouncing idle has something to do with your throttle positioning sensor(tps). Or if its not that its more then likely your iac valve on your intake manifold. There is a screen in there that sometimes gets carbon build up and jus needs to be cleaned out. Try cleaning the iac valve first. If thats not it then more then likely either the iac or tps could be shot.
Old Jun 8, 2011 | 01:01 PM
gheezy's Avatar
fast idle thermo valve, trust me it happens to all hondas and it's the valve that is always overlooked.
Old Jun 8, 2011 | 10:44 PM
BlackCatt's Avatar
Icon7 Re: 94 lude idle prob
Check out this thread from the FAQ,
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
bantum1cwa
Mar 5, 2014 06:25 AM
the_duce_duce
Sep 19, 2009 11:59 AM
BurgAccord95
Feb 16, 2009 06:30 PM
honda8882
May 6, 2003 03:32 AM
