burning mad oil..
Old Jun 3, 2011 | 10:16 AM
duckiexd's Avatar
Default burning mad oil..
hey guys i think my R is about to go out... im burning like a quart every 500-600 miles... but it seems like i burn oil when i cruise on the freeway (3.5rpm -4.5rpm) . everytime i redline it and i would wait for it to cool down and check my oil level and it seems like it didnt burn anything. idk if my piston rings are going out or my valve seals..
i did a compression test and my motor is 225-230 all across ( thats with WOT)
ohh and my rear bumper is covered with black spot! ..
i also get like... 21mpg...
any suggestion? TIA
Old Jun 3, 2011 | 11:41 AM
94rs-turbo's Avatar
Default Re: burning mad oil..
stop using mobile1 if you are and could be what you said, valve seals and or piston rings
Old Jun 3, 2011 | 03:37 PM
duckiexd's Avatar
could it be the oil??
Old Jun 3, 2011 | 03:51 PM
itr#1334's Avatar
Its just personal experience. Iv used mobil1 synthetic then switched to amsoil synthetic now i use gastrol gtx. All 3 oils burned the same amount of oil. So why not use the cheapest.
Old Jun 3, 2011 | 04:37 PM
racebum's Avatar
how many miles are on the engine and how hard has it been driven? usually a quart every 500 miles is the warning that you're going to blow a hole in a ringland or frag and exhaust valve.
worn rings, guides and harden, cracked seals are the usual cause. not just one of those, all 3
Old Jun 3, 2011 | 05:42 PM
duckiexd's Avatar
the engine probably got like... 110k?
damn... would a leak down test tell me about all of my problems?
Old Jun 3, 2011 | 05:43 PM
duckiexd's Avatar
yeaaa imma start using gtx
Old Jun 3, 2011 | 05:45 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
any suggestion? TIA
With those compression numbers, it might be a valve seal issue that's causing you to burn oil. Oil is going to burn off faster on the highway than it would around town. Sitting at 4-4.5k on the highway means the engine is rotating at 75 times per second with oil being squirted directly under the piston by the oil squirters. It's no surprise that hondas burn more oil on the highway.
Old Jun 3, 2011 | 06:04 PM
FULLYBUILT2.0's Avatar
try compression test or leak down test!! that will give you your answer!!!
Old Jun 4, 2011 | 11:13 AM
duckiexd's Avatar
yeaa im planning to do a leakdown test on mondayyy
and thanks guys for all of the help!
hopefully its only my valve seals.. so it wont be as much money to fix
Old Jun 13, 2011 | 10:04 AM
itr1244's Avatar
valve guides.
it took me 2 rebuilds to realize
Old Jun 13, 2011 | 10:19 AM
TOO MUCH TORQUE's Avatar
try a mmo piston soak. could be stuck piston rings
Old Jun 13, 2011 | 01:29 PM
jdmsta's Avatar
my car is at 110k miles and i have the same exact problem as you. black spots all over my back bumper as well. i really don't know whats the cheapest way to go about this. my mechanic said that if he were to dissassemble everything to fix whatever the problem is, its gonna cost an arm and a leg on just labor cost so he said the quickest and cheapest way is to do engine swap but i don't know where can i find a b18c5 long block from now a days.
Old Jun 13, 2011 | 11:37 PM
duckiexd's Avatar
whats that??
@jdmstaa hmotor sell long blocks! lol just hit up steve he'll take care of u
@1244 i took off my headers and 6 of the valves look white and 2 of them looks black...
Old Jun 14, 2011 | 11:18 AM
jdmsta's Avatar
thanks for the info...i'll check it out
Old Jun 14, 2011 | 11:25 AM
FormulaJDM's Avatar
I just fixed my bumper soot problem by accident. Last oil change went to the Honda brand synthetic blend oil. I know, i know...if someone told ME that I wouldnt believe them. Try it.
Old Jun 14, 2011 | 06:50 PM
itr1244's Avatar
whats that??
i'm talking about valve guides.. not the valve itself..
take the head off and see if u can see anything wrong.. get some friends help..
once you take the head out you can bring it to a machine shop and see if they see something wrong with it?
that's my guess of going the cheapest way possible
serjey15
Dec 4, 2010 07:20 PM
ultraplayer26
12
May 27, 2010 08:42 AM
Sl0wEK
Dec 5, 2004 10:12 PM
bubba your prison bitch
May 10, 2004 07:34 AM
CroSi
Aug 14, 2003 04:32 PM
