H22 coolant line routing
Old Jun 3, 2011 | 12:14 AM
CyborgGT's Avatar
Default H22 coolant line routing
First note that I'm still a sorry noob with a few aspects of the engine, and I think I'm right in guessing the cylinrical unit on the front of the plenum is the IACV and that under the throttle body is the FITV. So whether or not I'm right, those parts are what I'm referring to, haha
I'm putting a JDM H22A into my 4th-gen Accord. OBD1 motor with an OBD2 plenum, ordered from HMO, and I need to know what cooling ports to connect. The two hoses that didn't arrive cut are molded in such a way that it seems obvious where they go. One goes from where the rear water neck bolts to the engine to the driver-side port on the IACV. Another runs from the front of the two FITV ports to the thermostat housing. It looks like all I can do now is connect the other FITV port to the remaining IACV port, but the cut hoses they arrived with had different numbers printed on them. And I've seen instructional pics (OBD1 IM) suggesting a completely different routing. Anyone have pics of a similar setup? Thanks for any help!
MurtazaDSM
Nov 27, 2023 05:22 PM
AccordCoupef20b
Aug 22, 2015 07:44 PM
nathanjohnson2009
May 4, 2010 02:25 AM
powerdbygarrett
Apr 10, 2009 08:11 PM
D15Bbigred
Mar 8, 2007 06:08 AM
