doin a b18a1 swap into my 99 civic hx need help!
Old Jun 2, 2011 | 09:51 PM
bigdil14's Avatar
Default doin a b18a1 swap into my 99 civic hx need help!
Need some help.... I'm doin a b18a1 swap into my 99 auto civic hx... history on my car... use to be an auto with the cvt trans.. did a 5 speed swap. now did a ls swap currently using a 96 ex manual harness got everything hooked up.. bought a jumper harness and have it hooked up to a pr4 ecu... now here is the problem... I turn the key fuel pump does not work. Car cranks but no fuel. Somebody please help... funny thing is before I took out my original harness and ecu everything worked car started but I want to run a manual harness and ls ecu.
Old Jun 2, 2011 | 09:56 PM
Thmanx's Avatar
Default Re: doin a b18a1 swap into my 99 civic hx need help!
DA B18A1? Thats a pretty strange swap...
Why didn't you go w/ the more reliable and tried B18B?
Old Jun 2, 2011 | 10:10 PM
bigdil14's Avatar
Well I got the motor for a good price and thought it would've been a simple enough swap.
Old Jun 2, 2011 | 10:12 PM
Thmanx's Avatar
mm perhaps...
its always a bit more complicated when you end up doing different and older OBD #'s
some of those older B18A1's are OBD0 so that could be a real pain... What year is it?
Old Jun 2, 2011 | 10:19 PM
bigdil14's Avatar
Was told that's its a 93
Old Jun 2, 2011 | 10:56 PM
Thmanx's Avatar
can always check the head for the date stamp...
but if its a 93... it should be OBD1 so that should be ok, more or less lol
Old Jun 3, 2011 | 08:01 AM
bigdil14's Avatar
Ya its a 93.. but the motor isnt my problem....
eghatch9295
11
Feb 8, 2019 04:21 PM
jr13music
Feb 6, 2014 04:42 PM
cup cake
Jun 23, 2010 12:26 AM
dwillms
Jul 14, 2009 11:25 AM
bouttobeout
Mar 12, 2004 02:36 PM
