Super CLEAN Electron Blue Pearl '99 Si __SW Michigan
Old Jun 2, 2011 | 08:56 PM
DoNDoNJJJ's Avatar
Default Super CLEAN Electron Blue Pearl '99 Si __SW Michigan
Located in Holland Michigan. Looking to sell to upgrade to something like a high mileage TSX, TL or 03+ Accord
ELECTRON BLUE PEARL 1999 HONDA CIVIC Si ----- SALE OR TRADE
Testing Waters on my '99 Si.
$4700 FIRM ON KOSEI K1 OR $4200 FIRM ON STEELIES W/ Good Tires
It's Electron Blue Pearl in color, Interior is MINT (Car was babied and weekend driven the last 10 years)I have built this car and done all of the maintenance to be a problem free, good running/driving DD. It is currently my Daily driver.
Specs
-57,xxx miles (ORIGINAL)
-Salvage title, hit in the front in 2002 and was prof-repaired.
-B16a OBD1 Swap (Non-Lsd trans) (Mileage unknown so I will not make an idiotic stab at the mileage like most idiots on this website)
-LS Mesh wheels semi-polished
-Falken Ziex 195/55/15 (60-70%) NO Camber wear
Modifications
-Spoon res. covers
-Spoon Test Pipe
-DC Sports Stainless catback exhaust w/ Oval DC Muffler (sounds great)
-DC Sports header
-Professionally tinted windows, looks amazing
-Neuspeed springs (likely to be switched for stock if I keep the car any longer)
-Kenwood Radio/CD/Aux player
-PWJDM Carbon Induction "Whale *****"
-Wrinkle Red Valve Cover
-Running a OBD1 P30 Ecu with 9k Rev limiter. This car never sees above 7k under my ownership but it's there if needed
Prior to swap I removed all accesories and hoses from the engine, fully cleaned it and sprayed 3 coats of High Temp engine enamel. Fully re-assembled accessories and applied new gaskets, cleaned everything.
New Maintenance (5/15/11 - 5/25/11)...All of which is preventative. I don't drive anything unless it's tip top reliable. I should have reciepts for all of this.
***Engine leaks nothing***
-New coolant
-New Radiator
-New Oil Change/filter
-New Throw Out Bearing
-New Clutch Slave Cyl.
-New Intake Manifold gasket
-New NGK Blue Plug wires
-New Cam Seal
-New throttle body gasket
-New Driverside CV Axle
-New Front Rotors (4/10/11)
-Vtec Sylenoid removed and cleaned
-Intake manifold+throttle body cleaned
-New Transmission fluid (Honda MTF)
Extra Parts that I WILL BE INCLUDING that are Not installed
-H&R Springs (lesser drop for the winter, Will deliver better ride quality)
-Skunk2 Front Camber Kit, One needs a new ball joint
-Stock 99 Si Ecu
Bad:
-Oilpan is dinged/dented up. I will include a newer one with car. It doesn't create any oil leak issues however it should be replaced at some point.
-Ricer rear bumper
-4 small holes in the rear panel where a ricer spoiler was
-Check engine light obviously on for the test pipe thing.
-Minor crack on bottom area of windshield
Old Jun 3, 2011 | 09:14 AM
EJ8freek's Avatar
Default Re: Super CLEAN Electron Blue Pearl '99 Si __SW Michigan
Bump. Very nice.
Old Jun 3, 2011 | 12:39 PM
rayvo's Avatar
bump for clean... except the xmod rear bumper lol j/p
Old Jun 3, 2011 | 05:12 PM
Fibercation's Avatar
i'd pay 4k for it
Old Jun 3, 2011 | 07:20 PM
DoNDoNJJJ's Avatar
THanks for the kind words guys
Old Jun 14, 2011 | 08:56 PM
DoNDoNJJJ's Avatar
big price drop
Old Jun 18, 2011 | 02:03 PM
DuecedSol's Avatar
bump, pmd and texted!!
Rockale
Jun 6, 2014 06:57 AM
DoNDoNJJJ
Jun 7, 2011 06:15 AM
94HONDAHEAD
16
Sep 16, 2007 07:17 AM
SIfanatic
Sep 1, 2006 09:49 PM
97ITR239
Mar 28, 2005 09:17 PM
