TEIN HA question....height adjustment
Old Jun 2, 2011 | 12:40 PM
razorlude's Avatar
Default TEIN HA question....height adjustment
TEIN HA with helper spring ....had been fully lowered down maximum to the last thread that the adjuster plate can go and still got this kind of clearance(around 1 inch) what else can do done so i can lower it further without sacrifice the intergrity n durability of the shocks?
Old Jun 2, 2011 | 12:57 PM
slammedbbs's Avatar
Default Re: TEIN HA question....height adjustment
its a spring or coilover?
Old Jun 3, 2011 | 05:34 AM
razorlude's Avatar
coilover.....bought it from a used part shop from japan...
look like this
the 1 inch im toking abt is in between the tyre n the quarter panel edge ,i wish to lowered further so my 17" will be slightly tucked in the wheel well....only the rear end have this problem the front is good.
Old Jun 3, 2011 | 06:27 AM
slammedbbs's Avatar
when i had coil overs i took off one of the rings at the bottom. try to take off the very bottom ring and leave the bigger one on it looks like thats what the spring sits on i cant remember it been awhile
you wont get an inch though
Old Jun 4, 2011 | 05:04 AM
q16racer's Avatar
that bottom ring is the locking ring...DO NOT remove it.
i have these same coilovers and can slam my car to the ground, just choose not to.
are the shocks sitting if the fork perches fully?
Old Jun 6, 2011 | 09:24 AM
razorlude's Avatar
ya ya i know it works like a "lock nut" i won remove that
what do you mean by "are the shock sitting if the fork perches fully?" fork?? :? :D
Doed
Suspension & Brakes
Mar 27, 2013 12:32 PM
Lakalister
Suspension & Brakes
Jul 8, 2012 03:08 PM
static-x
Suspension & Brakes
Aug 13, 2006 08:44 AM
1SIKEG6
Suspension & Brakes
Feb 19, 2006 08:40 AM
