Transmission & Drivetrain Gearboxes, Differentials, Clutches
What would cause clutch pressure plate less pressure?
Old Jun 2, 2011 | 12:03 PM
9tailsfox's Avatar
Default What would cause clutch pressure plate less pressure?
hello there, I'm newbie around. Just curious and asking this silly question hope to get an answer. as far as I know one of a racing clutch like exp OS Giken racing clutch super single will be feel like hard like an old truck clutch. But If the clutch very often use like everyday. Would it make the clutch pressure feel softer because of the clutch pressure plate worn or bent?
example more clearly: I know no one will hold the clutch more 15 minutes. Without engine running, But if I use a longer nut bolt on the clutch pedal making it full pressing it continuously without let go for about 36 hours. What would happen to the clutch pressure plate? would it feel less pressure? If a stock clutch apply the above test would it be more softer and more less pressure.
any advice are welcome,as i said this is a silly question thank you
Vinde
Oct 30, 2014 08:14 AM
crazyguy
Jun 21, 2007 08:11 AM
sohcvtec1995
Nov 20, 2003 02:52 PM
Nextelbuddy
Jun 19, 2003 06:37 PM
IN VTEC
Jul 23, 2001 09:13 PM
