car wont. start plz helllppp
Old Jun 2, 2011 | 08:53 AM
chyanok92's Avatar
Default car wont. start plz helllppp
Hi I have a 1990 Honda civic dx and it will not start I have no spark I replaced the ignition coil and still nothing. So I hot doing some research. And it was saying to check my ecm or ecu so I have power going intonmy ecm so I thought it was my ecm. So ibreplacef it yesterday and still nothing the kite does not blink or anything when I turn my car on like irs post to . I checked my main relay and that's good if some one could help me out that would be grate cuz I am stuck I have no clue now
thanks
Old Jun 2, 2011 | 09:20 AM
4drEF's Avatar
Keyboard Humorist
Default Re: car wont. start plz helllppp
How did you test your main relay?
Was there output power to the ECU?
Check for power at A13 and A15 on the ECU.
If you have power then check your grounds.
Old Jun 2, 2011 | 09:32 AM
racejunke13's Avatar
Have you checked the Ignitor?
Old Jun 2, 2011 | 09:36 AM
ef92b's Avatar
this!
Old Jun 2, 2011 | 01:54 PM
chyanok92's Avatar
Where are the grounds at I can't seem to find it and I took my main relay and tested it the way it sait in the book and I have power to the ecm
Old Jun 2, 2011 | 02:34 PM
4drEF's Avatar
Keyboard Humorist
Ignitor will power the ECU?
Old Jun 2, 2011 | 04:53 PM
chyanok92's Avatar
Will the ignitor power the ecu and where are the grounds so I can check them too and where us the ignitor at
Old Jun 2, 2011 | 05:09 PM
4drEF's Avatar
Keyboard Humorist
A16 and A18 on the ECU are grounds.
Do a continuity check from those to chassis.
The ground lugs are found at the thermostat housing.
Also make sure the battery to chassis and the tranny ground are all good.
This is the ECU ground lug on a newer engine - same location though.
However, it's odd that you aren't getting a Code 0 if you just don't have ground.
Are you sure the ECU isn't powering up?
You said the light "does not blink or anything" - but now that I re-read maybe you meant the dash light isn't blinking.
Stare at the window on top of the ECU and see if the LED blinks when you turn the ignition switch from 'OFF' to 'ON'.
No, the ignitor doesn't power the ECU.
I was being a smartalec when I responded with that question to 'racejunkie'.
However, he have a point - only if your ECU is actually powering up.
So if the ECU is powering up, and you have no spark, then the problem lies within the distributor.
Common problem is the ignitor, but obviously you would want to troubleshoot before throwing parts at it.
Old Jun 3, 2011 | 03:42 AM
chyanok92's Avatar
Okay so.thoes are the grounds .. and yes I ment that my ecu luke on my ecu is not blinking or anything. When I turn my ignition on or off it does nothing
Calundeen
May 20, 2019 08:02 AM
AndyDaSilva
Jun 27, 2015 09:01 AM
winquest1000
Jun 30, 2014 10:10 AM
samx227
May 17, 2014 06:14 PM
md88hfcrx
Dec 12, 2005 11:58 AM
