What manual bracket will fit ITR?
What manuel steering rack will fit ITR?
https://honda-tech.com/zerothread?id=184202
Does this method the true alternative to none power steering... I know with the belt remove its a much slower reaction in steering, and when i hit pot holes or break traction the steering is crazy....
does that method truely help? or should i find a way to get a manual steering rack?
edit- bracket- steering rack..
-Jordo
[Modified by Jordo, 9:50 PM 9/30/2002]
-Jordo
"Manual Bracket"? Do you mean manual steering rack?
Mattj
Mattj
Is there a steering rack that will fit?
Mike K did it... not sure if it was a dx or cx rack, they might be the same. Something to consider is the ratio is alot bigger then the itr ratio. Mike K did not care, cause he was a drag ****
most who disable the p/s rack (including myself) think that the trade off is well worth it..
more effort but better road feel,
at high speeds you dont even know its not on
the only pain in the *** is those pesky 3 points turns...
the remedy for that:
take your pansy *** to the gym!
, which im dealing with now, and will deal with
NOman0608
Jan 25, 2009 07:17 AM
BoOsTiN Dc2
Dec 17, 2005 08:51 AM
